whats speed the ABS actives?
Old Aug 12, 2006 | 09:09 PM
emegge's Avatar
Default whats speed the ABS actives?
I want to know that whats speed the ABS actives? I want to test it on wet and dry road.
Accord '98 EX
Old Aug 12, 2006 | 10:39 PM
pos_cd5's Avatar
Default Re: whats speed the ABS actives? (emegge)
you obviously dont understand ABS.
ABS is active at all speeds, it activitates when it detects one or more of your wheels are locked up during braking. depending on the system and car it will activate sooner or later after detecting lock-up. 'sport tuned' ABS usually activate later to still give the driver a little more sense of control, but comes in to save his *** if he ***** up.
and why do you want to test it? if you really want to test it find a empty road with a shoulder consisting of gravel or dirt. have one side of your car on the pavement and the other on the gravel/dirt and drive to about 20-30mph and slam on your brakes, the wheel in the gravel/dirt will lock-up and ABS will kick in.
Old Aug 13, 2006 | 05:57 AM
sony224422's Avatar
Default Re: whats speed the ABS actives? (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">you obviously dont understand ABS.
and why do you want to test it? if you really want to test it find a empty road with a shoulder consisting of gravel or dirt. have one side of your car on the pavement and the other on the gravel/dirt and drive to about 20-30mph and slam on your brakes, the wheel in the gravel/dirt will lock-up and ABS will kick in.</TD></TR></TABLE>
I've heard it kicks in over a certain mile per hour actually, not sure what it is but some people have problems with it and the brake light in the dash won't come on until a certain mph they go over
Old Aug 13, 2006 | 07:08 AM
Duane_in_Japan's Avatar
Default Re: whats speed the ABS actives? (sony224422)
OK, someone is pullin your leg, the light should never come on until the computer sees a problem.
It can work at all speeds, but on the bad side, if the pedal vibrates only below about 10 MPH then you are getting ABS activation due to a bad Wheel Speed Sensor.
Old Aug 13, 2006 | 11:02 PM
sony224422's Avatar
Default Re: whats speed the ABS actives? (Duane_in_Japan)
i totally worded that completely wrong.
I meant to say, i've heard that if you're having the brake light come on due to the abs being bad or whatever, if you go under a certain speed it won't come on because its not engaged yet. But i dunno i could be wrong.
Old Aug 14, 2006 | 03:45 AM
If the ABS light comes on the ABS Computer disables the entire system. You are saying your brake light comes on, what does it look like. Are you also saying that on your car there is no "ABS" idiot light???
Old Aug 14, 2006 | 05:04 AM
Ross 2.0's Avatar
In a Junkyard near you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">If the ABS light comes on the ABS Computer disables the entire system. You are saying your brake light comes on, what does it look like. Are you also saying that on your car there is no "ABS" idiot light???</TD></TR></TABLE>
Don't quote me on it but i think the light will blink if the ABS is activated for an excessive amount of time like stopping on an icy hill or something
Modified by MooGoCow3 at 9:22 AM 8/14/2006
Old Aug 14, 2006 | 03:58 PM
pos_cd5's Avatar
Default Re: whats speed the ABS actives? (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by MooGoCow3 at 9:22 AM 8/14/2006</TD></TR></TABLE>
hmm, not too sure about that in real cars, but thats what happens in Forza for xbox. hahaha. the only way i was told oyu will know ABS is working is you will feel the brake pedal pulsing
Old Aug 14, 2006 | 04:07 PM
TheMuffinMan's Avatar
He knows where you live!
Yeah, if you put extreme pressure on the brake pedal, the pedal will vibrate and bounce a bit, and in the car I did Driver's Ed in it made a noticeable thudding sound. If you've driven a car on ice without ABS and then one with, haha I think you'd notice when it does/doesn't activate
(woot for no ABS)
Old Aug 14, 2006 | 05:39 PM
02 accord's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">(woot for no ABS)</TD></TR></TABLE>
So much fun in the winter and under hard braking in the rain.
Old Aug 14, 2006 | 06:57 PM
hondadude's Avatar
there is a minimum speed to activate the ABS, it's in the service manual.
don't mean to stir the pot but it's true
Old Aug 14, 2006 | 08:24 PM
pos_cd5's Avatar
Default Re: whats speed the ABS actives? (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">there is a minimum speed to activate the ABS, it's in the service manual.
don't mean to stir the pot but it's true</TD></TR></TABLE>
WITCH!!!!!! burn hiiiiim
01em2slvr
Honda Civic (2001 - 2005)
11
Dec 9, 2009 05:48 AM
shortlid
May 21, 2005 05:38 PM
Honda_NOLA
13
Oct 18, 2004 12:34 PM
Fraggle
Nov 2, 2003 11:03 AM
Tommy_Gunns
May 20, 2003 11:18 AM
