13:1 on pump gas?
Is it doable for a dd? A guy is selling some locally. 85mm 13:1 c/r Wiseco pistons w/ rings. If the car is tuned, can these be run on pump gas?
Im not thinking they are but I need some input from some of you all motor freaks.
I think it would be ok for your comp to be somewhere in the range of 12.5. My builder ported my combustion chamber ala endyne wherein hot gases are pushed more to a side. Not so sure whether its the intake or exhaust side. But the car feels and runs so much better with the fatter mid-range. Check out endyne's website and they have a civic running 13:1 I think. But what cams will you be using? If the ABDC is somewhere in the 46-47 area then stick with cr at 11.1. Anywhere between 49-55 will look for more static cr. Dynamic CR should be the key.
doable but not recomended.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Yes, if you take out a grip of timing. You can make more power on pump gas with less compression, and the car will run better.</TD></TR></TABLE>
listen to this guy he knows his stuff
It can be done if you are very very carefull. Make sure you have a perfectlly blueprinted motor, a perfect tune, a good knock detection system, very good working order cooling system, and keep a really good eye on everything. I personally wouldent run that high on the street becasue the motor won't last as longwith the high combustion chamber temps you will have but I don't know your situation.
my 2 cents.
my 2 cents.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16-bomber »</TD></TR><TR><TD CLASS="quote">read the sig... i dont remember who posted this quote... wasnt me... but its really good
</TD></TR></TABLE>i believe it was DonF that said that recently, i could be wrong, but i almost made that my sig too...it is absolute truth and knowledge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-cement-filled-EG-X »</TD></TR><TR><TD CLASS="quote">there is 100 octane on pump in most major cities.
X-eric-X</TD></TR></TABLE>
Yeah but for how much??
like camlob said it depends mainly on your cam selection and grade of fuel. For a static CR of 13:1 you will need a s2pro1-2, crower3, or equivelant. A good tune will aslo be key.
VtecKiDD
Feb 28, 2008 10:21 AM
