turbo questions
Old Aug 12, 2006 | 04:46 AM
boosted_90_hatch's Avatar
Default turbo questions
im wondering where the vacuum line that is on the compressor housing goes to??? this is on a t3
Old Aug 12, 2006 | 06:45 AM
mullenite's Avatar
Default Re: turbo questions (boosted_90_hatch)
this is a really basic question but normally it goes to the wastegate.
Old Aug 12, 2006 | 12:33 PM
Default Re: turbo questions (mullenite)
what if i do it to my bov???
Old Aug 12, 2006 | 03:07 PM
zrk666's Avatar
run a vac line to the intake mani. like the vacume source that goes to the fuel pressure reg is a good place.
Old Aug 13, 2006 | 11:58 AM
Default Re: (zrk666)
ok then were do i run the vacum line from the bov to?????
Old Aug 13, 2006 | 07:51 PM
slowcrxsib16's Avatar
Default Re: (boosted_90_hatch)
i ran my bov to a port on the tb
Old Aug 13, 2006 | 08:05 PM
abnaasefmb's Avatar
Default Re: (slowcrxsib16)
get one of these there pretty cheap and work great
Old Aug 13, 2006 | 08:12 PM
Default Re: (abnaasefmb)
ok so both the vacum lines from the bov and turbo go to that?
Old Aug 13, 2006 | 08:24 PM
abnaasefmb's Avatar
no i pull the signal for my wastegate from right in front of the throttle body. i use that for the boost gauge and BOV. you can just use the signal from the compressor for you wastegate as long as it's the right spring in it.
Old Aug 13, 2006 | 10:22 PM
k
Old Aug 14, 2006 | 02:41 AM
what if im just running the bov and no wastegate? then what
Old Aug 14, 2006 | 05:02 AM
bump
Old Aug 14, 2006 | 05:09 AM
JeDiMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_90_hatch &raquo;</TD></TR><TR><TD CLASS="quote">im wondering where the vacuum line that is on the compressor housing goes to??? this is on a t3</TD></TR></TABLE>
If Ive got the same thing in mind it goes to the wastegate. Ive got that line running to me external wastegate. Are internals the same?
Old Aug 14, 2006 | 05:10 AM
JeDiMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_90_hatch &raquo;</TD></TR><TR><TD CLASS="quote">what if im just running the bov and no wastegate? then what</TD></TR></TABLE>
You have to run a wastegate other wise you will free boost and boom!
Old Aug 14, 2006 | 05:33 AM
Loserkidwac's Avatar
Default Re: (JeDiMaster)
Wow this is geting good.....
Plug the vac port on the turbo, pull out the barb fitting and just thread a bolt into it, now for your BOV and Wastegate...you can either get a vac manifold or go to lowes/home depot and get some 3 port fittings and put barb fittings on the ends, if you are running a catch can you can just use the vac line for the PCV valve since you won't need it (if you are running a catch can)
I can take a picture of my setup tonight and maybe you'll see what i am talking about...but for more acctuate wastegate and boost guage run them off the mani and not the turbo vac port it will accoidate for any pressure loss over the charge piping and IC
Old Aug 14, 2006 | 10:17 AM
sikvic00's Avatar
where did you get that golden eagle vaccuum port thing from??
Old Aug 14, 2006 | 10:33 AM
HiProfile's Avatar
Default Re: (sikvic00)
My god, can't people use the search? And I don't mean just HT's search, going to google.com will find PLENTY of sources for an "Eagle Vacuum Manifold", along with turbo vacuum routing.
Here's how that style of vac mani is mounted/routed (top center of bay):
(yes its a 'clusterfuck' - its called having AC, OEM wire routes, transmission cables, tb cables, cruise cables, and oil lines)
<U>You will want to seal the port on the turbo compressor, don't use that.</U> You want to take a vacuum source *after* the throttle body and run it *BOTH* the blow-off valve AND the wastegate. If you run the lines in some other fasion, niether will work as intended. If you don't have the wastegate connected to a vacuum source after the TB, you will severly overboost. If that happens, you will either snap the overspun turbo shaft or just blow up your motor.
Old Aug 14, 2006 | 10:43 AM
CBURKE's Avatar
And never tap into your FPR, you get fuel press from there and you dont need that vac going any where but to the intake manifold
Old Aug 14, 2006 | 01:27 PM
Default Re: (CBURKE)
ok so if i plug the one on the compressor and then route the one from the bov to the tb im good?
Old Aug 15, 2006 | 06:49 PM
bump
Old Aug 15, 2006 | 07:27 PM
abnaasefmb's Avatar
https://honda-tech.com/zerothread?id=1263795
here is what i did. when using the intake manifold for my wastegate i would lose 3psi in the upper rpms. so i drilled and taped the charge pipe 1/8 npt
you can see here, it goes to the boost controler
here is the line to the BOV off the vac manifold. for me this works really good.
Modified by abnaasefmb at 4:41 AM 8/16/2006
Old Aug 15, 2006 | 10:53 PM
Default Re: turbo questions (abnaasefmb)
ok so im going to run my bov vaccum line to the fitting i put at teh lines up by the fire wall and im going to seee what happens
Old Aug 16, 2006 | 07:08 AM
nelsmar's Avatar
BOV goes to manifold. it uses the pressure diffeence between the pipe and the vacuum from the motor while the TB is shut to open the BOV. if you have a helper valve (lower barb on greddy TYPE S) it helps to hook it as close to the turbo as you can. as it will help open the BOV with slightlymore pressure.
Old Aug 16, 2006 | 11:45 AM
that makes sense
mcdonoughEk00
Mar 3, 2014 08:50 AM
racingchef
Jun 8, 2012 10:53 AM
90LSpimpin
Sep 10, 2005 04:47 AM
Ricey McRicerton
Sep 23, 2003 04:04 AM
_Endless_
Aug 30, 2002 06:30 PM
