rear disc part name??
Old Aug 11, 2006 | 08:48 PM
DaCRXboi's Avatar
Default rear disc part name??
hey guys, wat is the name of the part that attach on to the rear disc brake and it also connected to the e-brake cable (not the brake fluid line). Cause i missing that part and i don't know the name so i could order it for a 90-93 integra disc brake.
Modified by DaCRXboi at 9:37 PM 8/12/2006
Old Aug 12, 2006 | 10:35 AM
saaron34's Avatar
Default Re: rear disc part name?? (DaCRXboi)
the emergency brake/parking brake cable? pretty sure you order the parking brake cables for a 90-93 integra. I ordered mine for a 91 LS.
a picture of what youre asking a name for would help, if that is not it.
Old Aug 12, 2006 | 08:40 PM
DaCRXboi's Avatar
Default Re: rear disc part name?? (saaron34)
i have the e-brake cable. iim looking for a bolt on part that is on the disc brake, that allow u to hook up the e-brake cable on it.
Old Aug 19, 2006 | 01:15 PM
saaron34's Avatar
here, in this picture, what are you missing?
my guess is you are missing the L Bracket, in which case your part numbers would be: 43247-SH3-931 -arm right
43267-SH3-931 -arm left
there are bolts youll need too. if you need that part number, its 45240-SC2-003 BOLT, FLANGE (8X22)
Old Aug 19, 2006 | 01:23 PM
Ahknodd's Avatar
That's a great picture...
looks to me like he is missing all of that except the ebrake cables since he said he had those. Seems like you need the brake with it's mounting bolts, the spring and nut it's on, the cotter pin and stud that hold the cables on to the ebrake 'swing arm', and what ever the swing arm thing pushes to engage the brakes. I'd go to a junk yard and just look at another set of brakes and just take parts from that. Or if you have a good Acura dealer with a decent parts dept. go there and they should be able to pull up a pict of the entire rear trailing arm and rear disc brake/caliper assembly. Then you can get the names of everything and part numbers. If you don't a dealer near by to do this I can get a print out for you from my dealer here. Let me know if you need more help. Lates, Davey
Corksil
Aug 14, 2009 02:11 PM
Nisif
Jun 6, 2008 07:43 PM
guero2craze
Aug 29, 2007 09:28 AM
Turbo Dan
Aug 8, 2006 07:05 AM
lilman4o8
Jun 9, 2005 07:33 AM
