A/C retro-fit to R-134
Old Aug 11, 2006 | 07:00 PM
Gsr94black's Avatar
Default A/C retro-fit to R-134
Ok, here is the problem:
this is long....
I have a '90 teg for a daily driver and when i bought the car the a/c was blowing warm. So i have retrofitted three cars now in the past and i figured this would be easy too. So i took the new valve stem that you screw onto the exisiting valve stem and screwed it on like you are suppose to. I then hooked the hose up and got a can to start filling...well nothing happend....found out the stem was missing a piece fom the inside. The can didn't empty at all so i decided to go by another stem. I was able to convince Autozone to open a recharge kit box and give me the valve out of there b/c it seemed to be the only on that fits. I go home, screw that one on and retry to fill it. It finally fills but takes about a half hour for one can....not right. Well the a/c was blowing cold and warm...it would be blowing cold and then randomly blow warm and i have no idea why. I only put one can in and that was about a month ago. I went out of town last week and the car just sat while i was gone. I came back and the a/c blew nothing but outside air. I then went to good old autozone again to get another can with stop leak and refrig mixed in one. I tried to fill it and nothing happend at all this time...the can didn't empty one bit. I took the valve off again and it was all f-ed up and wouldn't let the freon through. I again asked autozone for a new vavle and this time they said no. I then asked if this was even the correct valve and they said they couldn't tell me b/c they had no idea. I then came home and decided to just empty the rest out of the lines so when i figure out how what piece i need it will be ready to go. The first 3 sec of emptying was freon and the last 30 sec was nothing but hot *** air....why? So the main question i have after all this crap is what valve piece do i need? There has to be a certain size or something. Can anyone help me here?
Thanks
Old Aug 11, 2006 | 07:41 PM
845_dapek's Avatar
Default Re: A/C retro-fit to R-134 (Gsr94black)
i personally work at autozone and those stems and r-134's are horrible, customers come in and complain all the time how the things dont work and how the can's dont even let air out.
Old Aug 11, 2006 | 08:39 PM
G2IntegraGS's Avatar
Default Re: A/C retro-fit to R-134 (gsrteggyflyin)
Stay away from stop-leak. You'll probably end up clogging alot of the tiny holes in parts like the expansion valve and condersor. Also, i'd change the actual valve steams inside the cars r-12 fittings. That turned out to be my only leak but using the stop-leak had ruiined my whole a/c system.
Old Aug 11, 2006 | 08:40 PM
ohh and freeze-12 gets alot colder than r-134a in car designed for r-12.
Old Aug 11, 2006 | 10:41 PM
all-mtr-teg's Avatar
Default Re: (G2IntegraGS)
I used to work for autozone, can't even begin to tell you how many customers came in and complained about the retrofits damaging their cars. But when I got to investigating the situtation, it turns out the customers didn't change orifice tube, or the R-12 was still in the system, black death had already occured, or one of many other possible problems with the system before even trying to retrofit. Anyways, best thing to do would be to get a good a/c hose kit and measure low, and high side lines. Low side should be about 40-55 psi depending on ambient temp. and high should be around 300-340 psi again depending on temp. If low side is extremely high, then you most likely have a clogged line, probably orifice tube.
Old Aug 12, 2006 | 11:53 AM
Gsr94black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS &raquo;</TD></TR><TR><TD CLASS="quote">ohh and freeze-12 gets alot colder than r-134a in car designed for r-12.</TD></TR></TABLE>
what is freeze-12 and how hard is it to get and install?
Old Aug 12, 2006 | 01:11 PM
IHTFP's Avatar
Default Re: (Gsr94black)
i had a shop do my retrofit for my da....
**** working on ac
Old Aug 12, 2006 | 09:33 PM
Gsr94black's Avatar
Default Re: (IHTFP)
so no one knows what size valve i actually need to get this taken care of or where i can buy the correct one without getting ripped off?
EgHatchy96
Jul 25, 2013 10:44 PM
jmdinn
Nov 4, 2012 07:41 PM
phoenix_iii
Mar 28, 2007 10:27 AM
vinuneuro
Feb 18, 2004 08:00 AM
ragejed
Sep 5, 2002 03:55 PM
