***H2B WITH WIRE TUCK***!!!!
Old Aug 11, 2006 | 05:30 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default ***H2B WITH WIRE TUCK***!!!!
UPDATE!!! All this hard work you seen done here is up for sale at a hell of a price, car runs amazing motor burns no oil does not smoke at all and the civic type r transmission shifts a smooth as if it were brand new, there are many people that can vouche for this car to verify how fast and sweet it is, naalltheway1320,jdmh22gsr,jdmchop,nagsrhatch, anyway thanx for lookin
6500obo
Well i just started my wire tuck and H2B swap yesterday and all i can say is im excited. I pulled the h22a w m2b4 and started my wire tuck....what a pain in the *** this is i only suggest doing this if you love love your car and plan on holding it for a while cause after all the work and time you put in it it would be a waste to turn it around and sell it
pics of the engine comp looks like after i pulled the motor
Pic of the engine comp after i pulled the wires thru the firewall and prepared them for relocation
Pic of the interior before i pulled the dash off
Pic after the dash was taken off
some more pics sofar many many more to come
OH YEA THE NUMBER ONE REASON FOR MEEEE TO GO H2B
Modified by H22EHSI at 11:20 PM 11/23/2006
Old Aug 11, 2006 | 05:40 PM
3.point.2's Avatar
you pulled the motor to do a wire tuck?
Old Aug 11, 2006 | 05:43 PM
Default Re: (h23eg)
and HHHHHHHHH22222222222BBBBBBBB
Old Aug 11, 2006 | 05:45 PM
3.point.2's Avatar
Default Re: (h22egsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22egsir &raquo;</TD></TR><TR><TD CLASS="quote">and HHHHHHHHH22222222222BBBBBBBB</TD></TR></TABLE>
i dont know much about the h2b plate other than what it does, but why does the motor have to be pulled for that?
Old Aug 11, 2006 | 05:50 PM
Default Re: (h23eg)
well i wanted a full blown wire tuck(no heat no vents no nothing) all headlight and fan wires will be ran thru the fenders and all of the engine harness will be ran into the car on the back of the block....as for the h2b it requires me to weld the stock trans mount brackett i removed for the h22 tranny to fit, and you need to grind the back of the block a bit, remove h series mounts and add B series mounts and a bunch of other **** plus i wanted to paint the engine bay and make it look ppuurrrttyyy
Old Aug 11, 2006 | 06:46 PM
Rad Racing's Avatar
Bart Taylor Look-alike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22egsir &raquo;</TD></TR><TR><TD CLASS="quote">well i wanted a full blown wire tuck(no heat no vents no nothing) all headlight and fan wires will be ran thru the fenders and all of the engine harness will be ran into the car on the back of the block....as for the h2b it requires me to weld the stock trans mount brackett i removed for the h22 tranny to fit, and you need to grind the back of the block a bit, remove h series mounts and add B series mounts and a bunch of other **** plus i wanted to paint the engine bay and make it look ppuurrrttyyy </TD></TR></TABLE>
Yeah, it's a bitch to try and do the H2B without pulling the motor.
Oh yeah, so far so good. Goodluck it's well worth the little extra effort to make this kit work
Old Aug 11, 2006 | 07:23 PM
Downey's Avatar
Default Re: ***H2B WITH WIRE TUCK***!!!! (h22egsir)
pretty cool. cant wait to see pics of it finished.
Old Aug 11, 2006 | 07:26 PM
the jdmchop's Avatar
Default Re: ***H2B WITH WIRE TUCK***!!!! (Downey)
Old Aug 11, 2006 | 07:38 PM
cambopheonix56's Avatar
Default Re: ***H2B WITH WIRE TUCK***!!!! (anti-lag aka JDMCHOP)
h2b
Old Aug 11, 2006 | 07:39 PM
BlueIntegraBoy's Avatar
Default Re: (h23eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23eg &raquo;</TD></TR><TR><TD CLASS="quote">
i dont know much about the h2b plate other than what it does, but why does the motor have to be pulled for that?</TD></TR></TABLE>
You have to grind a small portion at the back of the block.
Old Aug 11, 2006 | 07:42 PM
Default Re: (BlueIntegraBoy)
yup def do gotta do it right to
Old Aug 11, 2006 | 07:44 PM
Never liked the cable linkage from my old Type-S. Didn't have a solid shift feel like the rod linkage.
Old Aug 11, 2006 | 08:27 PM
shyboi4u's Avatar
G.L. with the project.
Old Aug 11, 2006 | 08:34 PM
null.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Never liked the cable linkage from my old Type-S. Didn't have a solid shift feel like the rod linkage.</TD></TR></TABLE>
i like it with my swap, i swapped the bushings and it felt like a shift linkage again. it's much smoother, and you dont' have to deal with the bitch pin, adjusting the screw to your liking, or deal with exhaust clearance
Old Aug 11, 2006 | 08:44 PM
Santys EK's Avatar
Default Re: (null.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboi4u &raquo;</TD></TR><TR><TD CLASS="quote">G.L. with the project.</TD></TR></TABLE>
Old Aug 11, 2006 | 08:59 PM
Sean Juan's Avatar
Default Re: (h23eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23eg &raquo;</TD></TR><TR><TD CLASS="quote">you pulled the motor to do a wire tuck?</TD></TR></TABLE>
Where have you been?
Old Aug 11, 2006 | 09:12 PM
dat_flip's Avatar
Default Re: (Grip King)
looks good
Old Aug 11, 2006 | 10:40 PM
itekdu's Avatar
Default Re: (h23eg)
lol
Old Aug 11, 2006 | 10:48 PM
spoonef's Avatar
Default Re: (itekdu)
Let us kno how the bseries tranny feels after putting it on
Old Aug 11, 2006 | 10:57 PM
shynop
Guest
Posts: n/a
Default Re: (h23eg)
Old Aug 11, 2006 | 10:59 PM
macDelli's Avatar
i want this set-up
Old Aug 12, 2006 | 05:09 AM
EATIN UP UR BSERIES's Avatar
thats what imtalking about...keep up the good work...
Old Aug 12, 2006 | 05:27 AM
JDMroyEG5turbo's Avatar
Default Re: (EATIN UP UR BSERIES)
good luck and keep us posted
Old Aug 12, 2006 | 05:35 AM
Default Re: (JDMroyEG5turbo)
Definitlly will keep you guys posted, thanx for the support, it really motivates me i cant wait to finish!!!
Old Aug 12, 2006 | 08:17 AM
h22Sicoupe's Avatar
looks good. goodluck.
