GSR engine Diagnose
Old Aug 11, 2006 | 03:39 PM
AZNracerx1989's Avatar
Default GSR engine Diagnose
I have a GSR engine that I got ripped off on... It has bad compression on one of the cylinders. When the engine is on, I pulled the spark plug wires off on each cylinder and all cylinders made the car go rough idle except the one with the bad compression. Also, the spark plug is black on that cylinder. I do not get blue smoke. Anyone know the problem? I am looking to rebuild my engine.
Old Aug 11, 2006 | 03:44 PM
oldskoolkid's Avatar
Default Re: GSR engine Diagnose (AZNracerx1989)
id pull the oil pan off and pull that piston out and replace the rings on it unless u wanna do a full rebuild then pull the whole motor out and redue everything (bearings, rings, hone, resurface, head gasket and a few other things) that would probably only run u about 500ish with machine shop work. up to u. the black spark plug just means its running rich
Old Aug 11, 2006 | 04:30 PM
it could be just valves... but i hear knocking noise when I rev or run so I think it might be piston rod knock
Old Aug 11, 2006 | 04:35 PM
jdeemseerx's Avatar
you can rent a compression tester with the gauge, pull the plug on that cylinder crank the motor until you get a steady reading.. pour a drop or 2 of oil straight into that cylinder then do the test again.. if the compression results are better you have bad piston rings
Old Aug 12, 2006 | 09:41 AM
axtran's Avatar
doesn't have to be bad comp - could be injector, spark plug, or your ECU. happened to me too. i was pissed, but luckily a friend had an extra P72 USDM.
Old Aug 12, 2006 | 10:40 AM
fmrprojects's Avatar
Default Re: GSR engine Diagnose (EgSick6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgSick6 &raquo;</TD></TR><TR><TD CLASS="quote">id pull the oil pan off and pull that piston out and replace the rings on it unless u wanna do a full rebuild then pull the whole motor out and redue everything (bearings, rings, hone, resurface, head gasket and a few other things) that would probably only run u about 500ish with machine shop work. up to u. the black spark plug just means its running rich</TD></TR></TABLE>
what a retard. you need to pull the head off to get the piston out
Old Aug 12, 2006 | 11:11 AM
I did a compression test. Thats how I know one cylinder is low.
Old Aug 12, 2006 | 03:48 PM
jdeemseerx's Avatar
so what else did you do so far? did you try the wet test? is that injector clogged?
blackeg
Sep 18, 2011 09:09 AM
nengx07
20
Feb 6, 2009 08:10 PM
ZRose
Oct 29, 2008 02:45 PM
1SlowSi
Jun 12, 2005 11:07 AM
93SSPHatch
May 30, 2002 04:27 PM
