carbon fouled exhaust valves, how to clean?
Old Aug 11, 2006 | 09:43 AM
85's Avatar
85
Default carbon fouled exhaust valves, how to clean?
My Ex valves are dirty i know they are and i was wondering if there is any way to clean them up without having to pull the motor apart.
Old Aug 11, 2006 | 12:46 PM
Enzo Speed's Avatar
Default Re: carbon fouled exhaust valves, how to clean? (hks85)
Nope. Carbon fused exhaust valves are nearly impossible to clean. I've experimented with them before - I had 8 different valves sitting in 8 different types of solvents and let them sit overnight. It didn't do anything. The only real way to clean off the carbon is to take the valves out and hit them with a stripping wheel followed by a polishing wheel. It's a very time consuming process. It took me a couple of hours to do all my valves:
Old Aug 11, 2006 | 01:00 PM
85's Avatar
85
Default Re: carbon fouled exhaust valves, how to clean? (Enzo Speed)
I have a 98' Mazda Millenia (2.5L V6) with 90K on it and the ecu keeps throwing a 02 sensor code, i changed it and its still coming up. Ive herd that the motor in my car is known for throwing codes after carbon fouls the ex valve. So im assuming that's the prob.
Old Aug 11, 2006 | 01:02 PM
Enzo Speed's Avatar
I'm not sure how fouled valves can cause o2 CELs. Maybe try some Seafoam and see what happens.
Old Aug 11, 2006 | 01:17 PM
unknown0001's Avatar
Use a wire wheel or wire brush. I've used this on a bunch of set of valves and it cleans them up fine.
The face of the valve you won't get fully clean due to the pitting on it from the heat and temperatures, but the stem and the rest of the valve you can clean up fine and without any damage to it.
Old Aug 11, 2006 | 05:35 PM
stumpyf4's Avatar
Default Re: carbon fouled exhaust valves, how to clean? (Mr.RHTuner)
Wire wheel works good. Get a brass bristle one since it's less aggressive than a steel one.
Old Aug 11, 2006 | 05:53 PM
85's Avatar
85
Default Re: carbon fouled exhaust valves, how to clean? (stumpyf4)
Ive cleaned valves before but i was hoping their was some way i could get them cleaned off without pulling the motor apart. such a pain in the ***...
Old Aug 11, 2006 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hks85 &raquo;</TD></TR><TR><TD CLASS="quote">Ive cleaned valves before but i was hoping their was some way i could get them cleaned off without pulling the motor apart. such a pain in the ***...</TD></TR></TABLE>
then the only way is a some kind of solvent(SP?). What I did on my b18b rebuild was dip the head in varsol for a few hours then clean it as much as I can with a normal plastic bristle brush and keep repeating the process till my it goe the cleanest possible without taking it appart
Old Aug 11, 2006 | 08:29 PM
BuddhaSiR's Avatar
What is the actual code? Maybe i can help you diagnose it. Should be a P01?? code. There are a ton of 02 sensor codes.
Old Aug 11, 2006 | 10:05 PM
85's Avatar
85
Default Re: carbon fouled exhaust valves, how to clean? (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">What is the actual code? Maybe i can help you diagnose it. Should be a P01?? code. There are a ton of 02 sensor codes. </TD></TR></TABLE>
Oh man, i dont know. It actually turned off on its own so who knows... well see if it keeps up then ill get it checked and let you know.
scubacamper
Mar 11, 2015 05:49 PM
an2ny888
Aug 25, 2014 07:25 AM
raverx3m
Feb 23, 2014 05:21 PM
vtecn8ive
Sep 24, 2008 05:41 AM
vtecn8ive
Sep 19, 2008 01:23 PM
