93 civic si coupe brakes on 92 si hatch
yes it will...unless there is a difference with with the ABS and non-abs calipers/brackets then it probably wont.
if both cars have abs....or are non-abs then it's safe to do so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesihatch »</TD></TR><TR><TD CLASS="quote">are the callipers from the 93 si bigger too? will i have to get new callipers too??</TD></TR></TABLE>
why would they be bigger??
all I know is my 94 civic coupe si is NON-abs...but I once bought abs brake pads and they didn't work, didn't fit and looked like a bit different piston design would be setup for them.
The calipers/pistons will all be identical. They may vary like I said from abs and non-abs but the size of the rotors and calipers should be 99% the same
ya i just thought that b/c the rotor is bigger, then the calliper braket would have to be bigger, maybe my 92 civic si hatch calliper would not bolt onto the 93 civic si coupe calliper bracket. i guess i'll just have to get some frikinn brackets and just try it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesihatch »</TD></TR><TR><TD CLASS="quote">ya i just thought that b/c the rotor is bigger, then the calliper braket would have to be bigger, maybe my 92 civic si hatch calliper would not bolt onto the 93 civic si coupe calliper bracket. i guess i'll just have to get some frikinn brackets and just try it.</TD></TR></TABLE>
do it
like I said, if they are non-abs then they will work
do it
I have a 92 si non abs and swapped over to 93 ex front brake set up the 93 brake set up is bigger 10.2"and the 92si were 9.5"... so long story short no the caliper will not bolt up your gonna have to swap the entire spindle assembly.
CunninLynguist
24
Nov 22, 2006 11:50 AM
stevn
16
Nov 14, 2005 08:30 AM
chet
23
Jul 8, 2003 02:41 AM
