Help! Brake line trouble!
Alright, while replacing my brake lines I failed to use a flare wrench on my passanger front hard line and I stripped it pretty damn good.. I now have a 10mm flare wrench for future use but I still have a stripped fitting. So, what's the easiest way to remove and replace the fitting? I was thinking I could just snip the line and replace the end, but is there anything special I need to know about doing that? Any help would be great! Thanks.
Vice grips are the only way to go on that one...
to re-do the line you'd need a flaring tool and a new fitting. From what I've heard, flaring can be a bitch... you may want to practice on some junkyard lines first... and get a fitting while you're there...
I made the same mistake a while back before I knew of the wonderful properties a flare nut wrench posessed. For as often as I replace brake lines, vice grips fit the bill for that one mangled nut...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Easy Eddy »</TD></TR><TR><TD CLASS="quote">Thanks guys.. I snipped the sucker and made a new flare.. It took a few tries and about an inch of hardline before I got it right.
Cool, hope it was a double flare.
</TD></TR></TABLE>Cool, hope it was a double flare.
hondazccivic
Aug 21, 2008 11:41 AM
ill phil
Aug 6, 2003 11:52 PM
