Installing Shift Bushings
Old Apr 24, 2002 | 08:25 PM
Unjockable's Avatar
New User
Default Installing Shift Bushings
Anyone got directions on how to do this? What steps are there? Thanks.
Old Apr 24, 2002 | 08:48 PM
All Motor EG's Avatar
Default Re: Installing Shift Bushings (Unjockable)
easy to do. if you are talkin about the shift bushins on the shift linkage then there are only 3 bolts to under. Jack your car up and go under it. on your shift linkage contected to your tranny there should be a 12mm bolt to take off. then slide that stock bushing out and slide your new one in, then go to the middle of the car where you will see your shifter part. there are 2 12mm bolts to take out. then you slide the shift linkage out of the bushing and. put new on on. its like a 7 minute job.
Old Apr 24, 2002 | 10:13 PM
slim's Avatar
New User
teamkhr.com
directions are here
8Gomer9
Aug 21, 2009 09:46 AM
umair
Mar 27, 2009 03:27 PM
honda4674
Jun 24, 2006 12:45 AM
wowowee
Jun 30, 2005 03:49 PM
CivicRaping
Mar 25, 2005 05:47 AM
