ecu recommondations
Old Aug 11, 2006 | 12:05 AM
gsr1289's Avatar
Default ecu recommondations
any one have some good recommondations on ecus for a b18c1 that will be running buddy club spec 3 cams dual valve springs titanium retainers and more then likely flat head valves. would it be better to get some other type of ecu then the stock one if so which one or would i just be better off chipping the stock ecu and if so which chip lol.
thanks guys.
Old Aug 11, 2006 | 12:33 AM
BluLude's Avatar
Default Re: ecu recommondations (gsr1289)
p72 + hondata
Old Aug 11, 2006 | 12:54 AM
Dartanian's Avatar
If you aren't using a single stage yet, get one and then use a P28 with your choice of rom editor. Uberdata, Crome, Hondata, Neptune, etc all work well.
Old Aug 11, 2006 | 07:04 AM
gsr1289's Avatar
Default Re: ecu recommondations (Sleeper Style)
sorry still dont know everything bout ecu's but whats a single stage and where can i get a p72?
thanks
Old Aug 11, 2006 | 07:53 AM
iH8RICERZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr1289 &raquo;</TD></TR><TR><TD CLASS="quote">sorry still dont know everything bout ecu's but whats a single stage and where can i get a p72?
thanks</TD></TR></TABLE>
the stock gsr intake manifold has iabs (secondary butterflies), if you swap it out with a skunk2/aebs/jg/blox/etc. they are styled after the oem itr/b16a single stage manifolds. People who are all motor typically go with a single stage manifold, but not all. If you have a GSR, then your stock ecu is a p72. Only the obd1 ecu is chippable/tunable. Here's how all the years and obd breaks down:
92-95 civics/integras: obd1
96-98 civics/96-99 integras: obd2 version A
99-00 civics/00-01 integras: obd2 version B
So if your car is obd2, which ever version, you will have to get an obd2A or an obd2B-to-obd1 ecu conversion harness, then look for an obd1 dohc vtec ecu. PM me if you have any more questions.
Old Aug 11, 2006 | 08:32 AM
scB20teg's Avatar
Default Re: ecu recommondations (iH8RICERZ)
Covert to obd1 if your not already and run a chipped p28 (or similar ecu) with Crome.
ultrablackhatch
Sep 10, 2005 11:47 AM
BLK99VTECR
Aug 21, 2005 11:08 AM
acuraqc
May 18, 2004 11:07 AM
allstokhonda
Dec 1, 2003 03:40 PM
incognitoracerr
Sep 6, 2003 07:39 PM
