INTEGRA LS 01....WHAT DO I NEED FOR MY ENGINE TO SPRAY 75 SHOT SAFELY
I have a SKUNK2 exausht and SKUNK2 test pipe...and AEM cold air intake..OBX 4-2-1 headers....and sparkplug wires.. what else should i add to make my engine capable of spraying a 75 shot with no problem and no chance of blowing anything...
colder spark plugs NGK BKR7E, pemium gas, retard timing 2 degrees, do not use below 3000 RPM, make sure everything is in good working order, no fuel leaks, use a wet system,have fun
a dry system is perfectly safe on a 75 shot...i would know since i was using it for quite some time
Thanks alot..and i was thinking of pulleys and intake mainfold and throttle body next...after that i was going to get cams..whats a good cam to buy for the setup i will have..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heat55561 »</TD></TR><TR><TD CLASS="quote">Thanks alot..and i was thinking of pulleys and intake mainfold and throttle body next...after that i was going to get cams..whats a good cam to buy for the setup i will have..</TD></TR></TABLE>
I just put 403s into my 95 rs. Quite a good bump in midrange power, even untuned.
I'm about to throw on a 100 shot and see what happens. I've seen the dry shots work fine..but I still kinda feel uncomfortable with them and am gonna go with a wet kit.
Shutupnskate are you running nos too?
