engine Gurus I'm gonna stump you!!!!!!
Old Aug 10, 2006 | 08:28 PM
Vintech's Avatar
Default engine Gurus I'm gonna stump you!!!!!!
On earlier GSR engines can anyone find me the location of the factory oil cooler lines with pictures? i wanna see where i can attach oil cooler lines "obd1 jdm gsr"
Old Aug 10, 2006 | 10:49 PM
whoneedzvtec's Avatar
Default Re: engine Gurus I'm gonna stump you!!!!!! (Vintech)
hmmm. i could be wrong on this one but i dont think that there is any factory oil cooler lines.
Old Aug 11, 2006 | 12:48 PM
beaneg6's Avatar
Default Re: engine Gurus I'm gonna stump you!!!!!! (whoneedzvtec)
earlier gsr's didn't have oil coolers if i remember correctly!
Old Aug 11, 2006 | 01:35 PM
Vintech's Avatar
I read a post from awhile back, shomeone said that there are oil cooler lines fittings on earlier gen GSR motors, I don't know if this is true or not but, it would be nice if it was.
Old Aug 11, 2006 | 04:09 PM
non-VTEC's Avatar
the 94+ GSR engine does not have your normal engine oil cooler you find on most cars.
the oil cooler it uses is attached to the back of the block. it's used as an oil filter adapter and coolant is run through it to help keep the oil cooler....to me its a shitty idea since the coolant will get just as hot as the oil in most cases anyway.
#11 in this image is what honda calls an oil cooler:
Old Aug 11, 2006 | 05:29 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: engine Gurus I'm gonna stump you!!!!!! (non-VTEC)
Only the 94-95 models years (OBD1) for USDM GSRs had the oil cooler. It is he same as the ITR oil cooler.
To install this oil cooler, you need to switch the water pipe as well.
Old Aug 11, 2006 | 05:32 PM
stumpyf4's Avatar
Default Re: engine Gurus I'm gonna stump you!!!!!! (Dogginator)
This shows it quite well.
Old Aug 11, 2006 | 07:28 PM
JimBlake's Avatar
Default Re: engine Gurus I'm gonna stump you!!!!!! (stumpyf4)
Yes, that's exactly how my '95 GSR was.
Old Aug 12, 2006 | 04:24 AM
Vintech's Avatar
Default Re: engine Gurus I'm gonna stump you!!!!!! (JimBlake)
Yeah I was talking with a couple of buddies last night and they showed me that crazy oil cooler that the oil filter attaches to. My next question is where would it be optimal to place the oil cooler, i.e. where in the system. and does anyone have any pics of thier installs?
Old Aug 12, 2006 | 04:50 AM
Dogginator's Avatar
Daisy... Daisy...
You typically buy a kit that installs between the oil filter and the engine block like the factory oil cooler. The other option is to use an oil filter relocation kit. Consider adding a thermostat to divert oil away from the cooler when the engine is cold.
Old Aug 19, 2006 | 10:35 AM
Vintech's Avatar
Thanks guys
Old Aug 19, 2006 | 07:23 PM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vintech &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I was talking with a couple of buddies last night and they showed me that crazy oil cooler that the oil filter attaches to. My next question is where would it be optimal to place the oil cooler, i.e. where in the system. and does anyone have any pics of thier installs?</TD></TR></TABLE>
this thread should help some, https://honda-tech.com/zerothread/1721282 check down at the bottom of the page for a quick install diagram. there are also some good mounting locations pictured.
Old Aug 20, 2006 | 12:26 AM
F20Cteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
The design is good. It is meant to be useful when the engine is run hard. The oil temps can get up above 250 degrees. With the coolant at 200, the oil is being cooled effectively.
Don't knock what you don't understand.
&gt;&gt;&gt;&lt;&lt;&lt;
pityocamptes
May 26, 2015 03:45 PM
Sweetsystem
Mar 24, 2013 08:08 PM
T-sohctec
Apr 21, 2003 04:36 AM
94DelSolVTEC
Feb 1, 2002 06:31 PM
