K 2ND POST WHAT TIMING BELT DO I USE!!!!????? need to know asap!!
ok, so heres the situation.
.980" deckplate on a b18c bottom end.
WHAT TIMING BELT DO I HAVE TO USE???
THIS IS THE 2ND TIME I POSTED REFER TO THIS THREAD : https://honda-tech.com/zerothread?id=1638216
THE BELT FROM THE FOCUS THAT GUY TOLD ME TO USE IS NOT THE RIGHT ONE ITS WAY TO SHORT!!!
i need to know this asap! i need to get my car running!
k i dont have a DART TALL DECK
i have a GOLDEN EAGLE SLEEVED 85MM GSR WITH A GOLDEN EAGLE .980" DECKPLATE.
THAT TIMING BELT DOES NOT FIT. I TRIED IT LAST NIGHT
it goes over 1 cam gear and then its like at least a inch to short to fit over the 2nd one.
i just calculated it.
your deck is only 14mm taller then stock which is .5512". mine is almost DOUBLE yours at .980" ( or 24.89mm ) taller then stock.
so what now?
so what now?
Does your block have the GEM adjustable water pump idler? If not, good luck, because your gonna have to go custom..... And thats in the thousands of dollars range.... From my research....
just curious, who makes your deckplate? perhaps they can steer you towards where to get a belt that works with their kit...there has to be a belt for it, otherwise their kit is useless. good luck!
GEM makes the deckplate and used to mfg. a adjustable water pump idler that allows you to use a Gs-R belt. I have it on mine and it just fits....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VenGeanceDrag »</TD></TR><TR><TD CLASS="quote">Does your block have the GEM adjustable water pump idler? If not, good luck, because your gonna have to go custom..... And thats in the thousands of dollars range.... From my research....</TD></TR></TABLE>
nope i just have a stock gsr water pump etc. after a few trips to napa i MAY have found a belt that will fit. im going out to the garage right now to try it!
im going to call golden eagle today and see what they have to say about it also.
edit--- i think it might be about a tooth to big
Modified by B18 CYA at 9:51 PM 8/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA »</TD></TR><TR><TD CLASS="quote">
Modified by B18 CYA at 9:51 PM 8/11/2006</TD></TR></TABLE>
so yah i got ANOTHER belt and it fit pretty damn good until i lined up the crank and the cam gears, then on the intake side when i tried slipping it on, it sits on top of like 3 or 4 teeth then goes back to normal, this is the only spot it does this in.
Modified by B18 CYA at 1:49 AM 8/12/2006
peggytheteggy
May 17, 2012 11:47 AM
aquabob89
Nov 27, 2005 03:18 PM
