What's the right way
Old Apr 24, 2002 | 07:36 PM
m0t0rhead's Avatar
Default What's the right way
What's the right way to check timing and set it on an OBD-2 Accord ?... It *should* be set at 17 degrees advanced..
any good suggestions on timing advance ?
As far as I know 17 would be optimal.
Old Apr 24, 2002 | 09:16 PM
H23 Power's Avatar
Default Re: What's the right way (Escobar)
every car is different...so there is no optimum setting...the right way would be to use a timing light...
Old Apr 25, 2002 | 04:58 AM
m0t0rhead's Avatar
Default Re: What's the right way (01GSR)
I know to use a timing light
I wanted to know the step by step procedure for an OBD-2 Accord so I could set it myself tonight. Someone who knows help would be much appreciated.
And for all you ********* with smart remarks who don't enjoy helping peeps, NO i do not have a shop manual.
Old Apr 25, 2002 | 12:22 PM
SOHCArchangel's Avatar
i enjoy helping people but you must make an effort to help yourself first.
anyway, advance too much lose top, gain low
retard too much lose low, gain hi
if i didnt get my hondata i would have gotten an apex-i ITC .
But dont thank me since i dont eNjOy HeLpIn PeEpZ y0!
Old Apr 25, 2002 | 12:54 PM
m0t0rhead's Avatar
Default Re: What's the right way (SOHCArchangel)
I'm not talking about CAM timing. Advancing your cam will make you lose high end, retarding it will actually lose low but gain high.
Ignition timing dude!
Old Apr 25, 2002 | 12:59 PM
i am talking about ignition timing
i never knew there were electronic cam timing controllers
Old Apr 25, 2002 | 01:23 PM
CD8's Avatar
CD8
on my 96, obd2 you cannot adjust he timing at all. the distributor doesnt move. i thought this was true for all obd2's.
Old Apr 25, 2002 | 01:37 PM
Default Re: What's the right way (exaccord)
[QUOTE]apex-i ITC [QUOTE]
Old Apr 27, 2002 | 08:11 AM
m0t0rhead's Avatar
I can. I have a 97'.
Old Apr 27, 2002 | 08:14 AM
m0t0rhead's Avatar
You don't lose any power advancing your ignition timing. So if that's what your talking then I'm sorry but you're mistaken. The dyno has proved it.
Some people assume that advancing the cam will show gains but again the dyno has also proved otherwise. Retarding the cam 4 degrees will bring out decent gains in the upper rpm band. Advancing will kill your top end.
Old Apr 27, 2002 | 10:40 AM
urbanlegend21's Avatar
New User
advancing your timing can **** your valvetrain up though if run to far advanced, for to long
and I would like to know what dyno you are talking about?
civic j
Aug 17, 2007 08:10 AM
hondapwr
May 8, 2006 08:17 AM
AggAccord03
Jul 7, 2004 06:16 AM
2001TypeR
Aug 10, 2002 10:32 PM
tampaSi
Aug 16, 2001 04:16 PM
