Sway Bar for Ek hatch
Old Aug 10, 2006 | 02:49 PM
Santys EK's Avatar
Default Sway Bar for Ek hatch
which sway bars fit an ek hatch???
also i have a gsr one will it work?
thanks scott
Old Aug 10, 2006 | 04:01 PM
tha_badguy's Avatar
si sway will fit
but u need everything
Voyage34's Avatar
Default Re: Sway Bar for Ek hatch (Santys EK...905)
front or rear?
actually, either way, read this
Old Aug 10, 2006 | 04:09 PM
JDMFreak's Avatar
Default Re: Sway Bar for Ek hatch (Voyage34)
if you have the gsr rear sway bar (14mm) it will fit...you will need d-brackets and 99-00 si endlinks...you can still use your existing rear lower control arms
as for front sway bar...if you going to use 99-00 Si (26mm) you will need forks and lower control arm...i think that it...i cant remember what esle...Si Sway bar of course...
i think 96-00 Civic Ex (22mm) bolt right in...i think
Modified by JDMFreak at 7:36 PM 8/10/2006
Old Aug 11, 2006 | 08:54 PM
Santys EK's Avatar
Default Re: Sway Bar for Ek hatch (JDMFreak)
its the rear sway bar and i have megan racing lcas on my car now i know the d brackets dont work but it doesnt look long enough when i place it on the back of my car
^^^^ thats the GSR sway bar
im thinking of getting a si one
Old Aug 11, 2006 | 11:23 PM
Voyage34's Avatar
^^ doesnt look long enough how? the ends dont line up with the hoes in the lca's?
what endlinks are you using? ok an ek chassis you need to use the 99-00 si (em1) endlinks or equivalent aftermarket on all oem bars
Old Aug 12, 2006 | 07:51 AM
Santys EK's Avatar
thanks for all the help
im leaving now to get my em1 sway bar thanks
Diamond Co
Suspension & Brakes
12
Dec 3, 2012 08:39 AM
DC2#309
Apr 5, 2005 07:54 PM
RedGSR
Jun 10, 2004 01:57 PM
Amuse9
Dec 30, 2002 12:48 PM
ichibano
Jul 5, 2002 07:54 AM
