no tach
Old Aug 10, 2006 | 11:19 AM
redlinevq's Avatar
Default no tach
Hey I just got a 88 Civic DX 5spd with a D series motor and I have no tach. I wonder if anyone can tell me what speed each gear starts and ends in. Sorry for the newb question.
Thanks,
Robert
Old Aug 10, 2006 | 12:22 PM
La EF-8's Avatar
Default Re: no tach (redlinevq)
listen to the motor
Old Aug 10, 2006 | 12:32 PM
ludesrv's Avatar
Ball park is
60kmh first
100kmh second
140 third
unknown after that.
Get an Si cluster with factory tach! bolts right in!
Old Aug 10, 2006 | 12:47 PM
STDClayton's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Ball park is
60kmh first
100kmh second
140 third
unknown after that.
Get an Si cluster with factory tach! bolts right in!</TD></TR></TABLE>
my man above speaks the truth. hit up the junkyards!
Old Aug 10, 2006 | 01:04 PM
redlinevq's Avatar
Default Re: no tach (La EF-8)
its a quite motor so listening isn't as helpful as it was on my vtec prelude. As far as swapping out the dash, I really don't want to put the time into it, this is just my beater. What are those ranges in mph?
Old Aug 10, 2006 | 03:19 PM
IPimpInTheHatch's Avatar
8 screws sure is a lot of work
Old Aug 10, 2006 | 03:50 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: no tach (IPimpInTheHatch)
do you have your manuel? It has the reccomended shift points and top rpm for each gear.
Old Aug 10, 2006 | 06:00 PM
sierrakilo's Avatar
Its pretty much cake to get that cluster out of there and replace it with one from the pik-n-pull... otherwise you're guessing at best for shift points.
Old Aug 10, 2006 | 06:40 PM
janz3n's Avatar
Default Re: no tach (sierrakilo)
60kmh first
100kmh second
140 third
unknown after that.
are you seriouse about that? i hope not .. if you shift to third at 100 km/h you'll go past the redline.
Old Aug 10, 2006 | 09:14 PM
93cavRS's Avatar
Default Re: no tach (janz3n)
no u wont.....ive hit redline in 2nd and it sure is past 100km/h.....not mph
Old Aug 10, 2006 | 09:16 PM
janz3n's Avatar
Default Re: no tach (93cavRS)
really? whats your redline.. im pretty sure the d15 is about 6500. and at that rpm im only going about 80.. dx tranny. km's too.
Old Aug 10, 2006 | 09:27 PM
B6tizzleHatch's Avatar
if you cant get a si cluster, then just slowly get on it at the top of the gear til you find the rev limiter and watch your mph, then shift about 3mph under that and play it safe. my $.02
Old Aug 10, 2006 | 09:41 PM
RockinthEFhatch's Avatar
Default Re: no tach (B6tizzleHatch)
I have a Civic Si cluster for sale with 101xxx miles. IM me at Pooch1069
Old Aug 10, 2006 | 09:46 PM
TeamRedline89Hatch's Avatar
on mine, about 27, 55, 85, 100...could have gone more on 4th...D15B2 I/H/E
Old Aug 11, 2006 | 12:22 AM
rayzian's Avatar
I was on the highway doing 100kph and I downshifted to 3rd and it bounced off the rev limiter a couple of times, so I don't think you can do 100kph in second with a DX tranny if I'm hitting the rev limiter on third. Or maybe I was doing 120... I can't really remember
Old Aug 11, 2006 | 05:16 AM
janz3n's Avatar
Default Re: no tach (rayzian)
well.. im pretty sure 100 in 2nd gear is impossible.. even more impossible with an si tranny because your rpms would be higher at 100. so i dont konw what this guy is talking about. id like to see a video or something. and i dont really want to rev my d15b2 engine more then 6500 ... its my DD and i dont need to blow this engine.. its the third one to be in the car.. that i know of. and it doesnt burn oil so im happy right now. and i still rarely ever rev to 6500rpm anyways. anything more would be a waste to me. i only do it if im mad at someone infront of me .. so i scare them by screaming past them.
Old Aug 11, 2006 | 05:21 AM
Loserkidwac's Avatar
60kmh first
100kmh second
140 third
unknown after that.
I think most people missed the "KMH" its not MPH
100khm=62mph
Old Aug 11, 2006 | 08:14 AM
91slamedrex's Avatar
go up the gears till u hear a choking noise then u shift
Old Aug 11, 2006 | 08:28 AM
Default Re: (91slamedrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91slamedrex &raquo;</TD></TR><TR><TD CLASS="quote">go up the gears till u hear a choking noise then u shift</TD></TR></TABLE>
lol choking noise = rev limiter, which is EXACTLY what i said to do. not to flame but i dont think he needs to be told twice
Old Aug 11, 2006 | 09:06 AM
STDClayton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinevq &raquo;</TD></TR><TR><TD CLASS="quote">its a quite motor so listening isn't as helpful as it was on my vtec prelude. As far as swapping out the dash, I really don't want to put the time into it, this is just my beater. What are those ranges in mph?</TD></TR></TABLE>
dude, you don't take out the entire dash. it's two screws on top of the hood that encompasses your gauge cluster, two on the bottom on either side of the steering column, and then the hood comes off. after that, you will see two screws on both sides of the gauge cluster. unscrew them. unclip the wiring harnesses in the back and vss (vehicle speed sensor). that's it.
Old Aug 11, 2006 | 09:08 AM
JDMatt3's Avatar
Default Re: (B6tizzleHatch)
in other words...just shift when the car starts to cough...
Old Aug 11, 2006 | 09:30 AM
redlinevq's Avatar
thanks that was exactly what I was looking for.
Old Aug 11, 2006 | 03:16 PM
janz3n's Avatar
Default Re: (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">
100khm=62mph</TD></TR></TABLE>
no one missed that it was km/h, the highest i can go in km/h is 80 in second gear. theres no way of going 100.
Old Aug 11, 2006 | 04:01 PM
Default Re: (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">
no one missed that it was km/h, the highest i can go in km/h is 80 in second gear. theres no way of going 100. </TD></TR></TABLE>
Ah I see Well Here it is straight from my owner manual:
Recommended Shift Speeds
For Best fuel economy, and effective emissions control, shift at the speeds shown,
HF:
The HF model includes an Economy Driving Indicator(see pages 16 for instructions). Follow the indicator for the most economical shift speeds.
Cars sold in California do not have an Economy Driving Indicator, Use the following speeds as a guide.
Shift Up Normal Acceleration
1st to 2nd 15 mph (24 km/h)
2nd to 3rd 25 mph (40 km/h)
3rd to 4th 40 mph (64 km/h)
4th to 5th 47 mph (76 km/h)
CRX:
Shift Up Normal Acceleration Cruise From Acceleration
1st to 2nd 15 mph (24 km/h) 9 mph (14 km/h)
2nd to 3rd 27 mph (43 km/h) 20 mph (32 km/h)
3rd to 4th 39 mph (62 km/h) 33 mph (53 km/h)
4th to 5th 53 mph (85 km/h) 48 mph (77 km/h)
Si:
1st to 2nd 14 mph (22 km/h) 7 mph (11 km/h)
2nd to 3rd 25 mph (40 km/h) 20 mph (32 km/h)
3rd to 4th 36 mph (58 km/h) 30 mph (48 km/h)
4th to 5th 49 mph (78 km/h) 45 mph (72 km/h)
Maximum Allowable Speeds
The speeds shown are the maximum at which the car can be driven or downshifted in each gear without over-revving the engine.
HF
High Altitude Models California models Low altitude models
1st 26 mph (42 km/h) 30 mph (48 km/h) 33 mph (53 km/h)
2nd 52 mph (84 km/h) 59 mph (96 km/h) 65 mph (105 km/h)
CRX / Si
1st 35 mph (56 km/h) 30 mph (49 km/h)
2nd 60 mph (97 km/h) 52 mph (84 km/h)
3rd 90 mph (146 km/h) 79 mph (127 km/h)
offspringpunk14
Sep 8, 2009 05:53 PM
black7hatch
Dec 12, 2006 02:49 PM
sohctodohc
12
Oct 10, 2005 11:44 PM
importboi22
Oct 31, 2003 05:20 PM
Sketch_hs
May 12, 2003 07:11 PM
