How many mounting points....
Old Apr 24, 2002 | 06:23 PM
CKDC2's Avatar
Default How many mounting points....
for the Comptech Icebox not including down tube, and approx. where are they located?
Old Apr 24, 2002 | 09:18 PM
CKDC2's Avatar
Default Re: How many mounting points.... (CKDC2)
What, no one here has installed the icebox and knows how many mounting points it has, and where they are located relative to the factory mounts?
Old Apr 24, 2002 | 10:13 PM
BSQ's Avatar
BSQ
Go to http://www.sandmracing.com/scomptechicebox.html and you should be able to find your answer.
Old Apr 24, 2002 | 10:21 PM
1GreyTeg's Avatar
1 that uses a hole from the stock box and another that mounts just behind a stock box location. The down pipe intake tube is held in by a clamp near the transport lug.
The PIC in the directions is not really clear and kinda misleads you but, if you mount it with the outside bolt ,"one furthest from engine FIRST!" It will all fall into place.
Just get a beer and have a fun 30 to 45 minutes removing stock and installing Comptech ... Heres the Instructions: http://www.comptechusa.com/instructions/int_icebox.pdf
Good luck,
A.
Viorent Grip! EG
Jun 3, 2004 02:09 PM
Instg8er
Nov 14, 2002 07:20 PM
Understeer
Oct 5, 2002 12:54 PM
magic hat #9
Jan 25, 2002 07:21 AM
98R-641
Nov 29, 2001 09:29 AM
