ecu check code errors
hi guys
have a problem with my dc5, and i am getting a CEL light that comes on.
Where can i find the 2 pin jumper to get the error codes to display?
are the error codes the same for dc5 as the obd1 and obd2 ecus listed in the FAQ for the civic thread?
i dont know how to check it but i do know that if you disconnect your battery, step on the brake pedal, and reconnect your battery then the CEL should go off. what this does is it resets the system. its not the best way to go if you want to diagnose a problem but i did it to my car b/c i knew my problem was that more air was coming in b/c of my intake. thats just food for thought.
