LOL pics of my my cyl 2 has no compression.. funny
ok. i disasembled my engine. took out pistons rods etc.
NIce Coke Holder
i guess this is wut made my cyl 2 have no compression. hehe
... this sux cuz i am going to now rebuild the entire motor 2 months after the swap.. lame.
Modified by AnthraxVX at 1:11 AM 8/10/2006
NIce Coke Holder
probably happened because either i floated a valve or yes like the guy said above, burnt a valve. i dont have the much xp in tearin these down so i havent seen this before. but wutever, im replacing valves, springs, retainers, head gasket, rings, pistons, rod bearings, should be good for the win!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt »</TD></TR><TR><TD CLASS="quote">
Are there any threads in your spark plug hole?</TD></TR></TABLE>
yes there are
pic was taken with my phone that is why quality is low.
yes there are
same thing happened to me a couple months back https://honda-tech.com/zerothread?id=1639024
np, my new setup is going to pwn, im building the head since im going to actually use that for my turbo build, my bottom end im just going to get running 100% with new bearings and piston rings. so.. my new setup =
GSR head (of course)
SuperTech Stainless Valves coated
SUpertech Dual Valve Springs
Supertech Titanium Retainers
valve job done by portflow.. i believe its a port and police
im going ot get it tuned with just that, then i will use this head for my turbo motor build.. turbo motor will be that head with
b18A block with Eagle Crank, Eagle Rods, and CP pistons 9.1 comp probably, Eagle Sleeves, Billet head gasket
u think that will be able to handle about 16 boost? probably more but i want to run reliably with that setup, lemme know wut u guys think/suggestions.
all that for just 16 pounds of boost?? man jump that **** up if your doin al that. or 9.2 cr is to high, drop it to like 8.3-8.7 cr. boost is better with lower cr. the higher your cr the less boost you need to make high numbers. visit HMT and see what we got cookin.
pretty lame, i would upgrade the valvetrain while the head is off
hopefully it didnt strach your cylinder walls
You have iridium plugs? Had a retard with an SRT4 blow his motor because the tip broke off of his NGK plug, and he wanted a refund on it. I told him no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitally_remastered »</TD></TR><TR><TD CLASS="quote">all that for just 16 pounds of boost?? man jump that **** up if your doin al that. or 9.2 cr is to high, drop it to like 8.3-8.7 cr. boost is better with lower cr. the higher your cr the less boost you need to make high numbers. visit HMT and see what we got cookin.</TD></TR></TABLE>
Boost is not better with retarded low compression. There is absolutely no point in dropping your compression below 9.1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthraxVX »</TD></TR><TR><TD CLASS="quote">
yea, i know how boost and compression work
.. </TD></TR></TABLE>
Maybe you can explain it to digitally_remastered then
.. </TD></TR></TABLE>Maybe you can explain it to digitally_remastered then
1320DRAGWORKX
Mar 20, 2008 03:21 PM
FredoSP
Jul 28, 2003 09:09 AM
siis2fast
Jun 16, 2003 11:09 AM
Hope you managed to find the missing chunk of valve.
