Cat melted shut ....
Old Apr 24, 2002 | 05:37 PM
KevronsEG's Avatar
Default Cat melted shut ....
i think this happened what will it do
91 crx si with b16a1 with exhaust with cat and intake 255 fuel pump
Old Apr 24, 2002 | 05:41 PM
Urban Business
Guest
Posts: n/a
Default Re: Cat melted shut .... (CIV616)
it'll slow you down like a ****
Old Apr 24, 2002 | 05:43 PM
KevronsEG's Avatar
Default Re: Cat melted shut .... (TorteX)
can it happen
Old Apr 24, 2002 | 05:44 PM
crx(gator)'s Avatar
normally when a cat is clogged, you will here a pinging sound when you turn your car off...like i am hearing now...
Old Apr 24, 2002 | 06:05 PM
Urban Business
Guest
Posts: n/a
Default Re: Cat melted shut .... (crxgator)
heh if it melted shut you have no exhaust flow not a ping but a kapow! when that cat pops
Old Apr 24, 2002 | 06:32 PM
Mugen Dom's Avatar
look under ur car after driving it is ur cat red hot???? i mean red like red then that means its melted shut just get a new one while ur at it get a high flow cat
Old Apr 24, 2002 | 06:41 PM
FourthGenHatch's Avatar
Default Re: Cat melted shut .... (jdmB18hatch)
I got the Catco High Flow for $100 @ summitracing.com
Old Apr 24, 2002 | 06:42 PM
EP3_05's Avatar
Default Re: Cat melted shut .... (FourthGenHatch)
I am using the same one with my b16 swap and it has not failed or melted shut.
Old Apr 24, 2002 | 06:43 PM
pelotudo's Avatar
You have 3 options:
1. Get a new cat ($$$)
2. Take off your cat after it has been sitting a while. Get a long metal rod, and poke as hard as you can to bust it out (No $$$)
3. Sell me your 255 fuel pump for $25, then refer back to option 2.
I say go with option 3, that seems like the best choice
jB
Old Apr 24, 2002 | 06:52 PM
pelotudo's Avatar
Default Re: Cat melted shut .... (91civic)
91civic,
Which would you prefer? I have a test pipe on it right now, but am debating a high flow cat. I do not have emissions in my area, so they're not a problem. Should I stick with my test pipe or get a high flow? Any major differences in performance between each of them?
jB
Old Apr 25, 2002 | 05:47 AM
KevronsEG's Avatar
Default Re: Cat melted shut .... (PeloTudo)
well it is a high flow cat it started with this wistleing nosie sorry for spelling it sound like its right by the cat but i started to no have power when that started. Know i cant rev past 5
Old Apr 25, 2002 | 07:16 AM
89 CRX SI's Avatar
sounds like your cat. unbolt it(pain in the ****) and then start it up ... pop your ear plugs in and rev it and see if itll go past 5k. Then you know what your problem is. unbolt other side and take a pipe and beat up the innnereds
Old Apr 25, 2002 | 10:05 AM
SyndicateEH's Avatar
$100?!?! I paid $50 for my 2.5" Catco High flow
Old Apr 25, 2002 | 12:38 PM
*Boostwerks*'s Avatar
Default Re: Cat melted shut .... (SyndicateEG)
Yeah, I also only paid around 60.
hmmm.
Great quality cat's BTW
Old Apr 25, 2002 | 12:43 PM
Mugen Dom's Avatar
Default Re: Cat melted shut .... (Bryson)
where u guys get em for 60??? id like to find out
Old Apr 25, 2002 | 12:51 PM
customx_'s Avatar
New User
the direct bolt on are $100 each while the universal (weld-on) are around $50-60.
Old Apr 25, 2002 | 12:54 PM
Summit. This was about 4 months ago so the price may have changed.
Yeah, it's the 2.5" weld on one, not the bolt on.
Old Apr 25, 2002 | 12:57 PM
EP3_05's Avatar
91civic,
jB
I had a straight pipe on my car before I got the cat and it was extremely loud and raspy. So i bought the cat and the noise was toned down substantially. I didn't notice a performance difference either. I am still running the same times. I would personally recommend a high flow cat unless you like the loud noise or you are running forced induction.
Old Apr 25, 2002 | 01:41 PM
KevronsEG's Avatar
problem fixed melted cat
Old Apr 25, 2002 | 06:01 PM
MysteryWagon's Avatar
I also have a Catco cat, has not failed yet going on 2 years. Now it has a B16, lets see what happens.
bOOsTiNSoHcVtEc
Apr 13, 2004 09:07 AM
UA6 BALLER STATUS
Aug 20, 2003 11:23 PM
lsteggy
Apr 15, 2003 07:36 PM
