doing a mini-me swap have some ?s
Old Aug 9, 2006 | 07:14 PM
THEROPE's Avatar
Default doing a mini-me swap have some ?s
i have a 91 civic hatch std d15b1 dpfi
and im doing a mini-me using a d16z6 all my questions were answered by searching except 1.
where do i hook up the fuel return on the rail of the d16z6 head?
i was all over the TB and could not see it
i see the feed from the filter but no return
Old Aug 10, 2006 | 05:25 AM
THEROPE's Avatar
Default Re: doing a mini-me swap have some ?s (THEROPE)
help need an answer
Old Aug 10, 2006 | 05:30 AM
92integra_gs's Avatar
its suppose to be the that end of the fuel rail... should be a metal line there
if you got a service manual... check it there if not i would get one... or you can SEARCH ...
Old Aug 10, 2006 | 07:01 PM
THEROPE's Avatar
Default Re: (92integra_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">its suppose to be the that end of the fuel rail... should be a metal line there
ok you dont know what i mean
on dpfi intake manifolds there is no fuel rail
the feed line gets bolted directly in the TB from the filter
and like i said before i did run a search and i do have a SM
Old Aug 11, 2006 | 03:57 PM
THEROPE's Avatar
anymore idea's
Old Aug 11, 2006 | 05:52 PM
ok maybe this would be more clearer...
you are askijng where do you hook up the fuel return line that comes from your old b1 setup on your mini-me... if i am right...
your fuel return line should hook up in the fuel pressure regulator end (that is where my fuel return line is hooked up)
Old Aug 12, 2006 | 06:07 AM
mullenite's Avatar
if you still need it when i go work on my car today i can take a picture. i think you are a member on AD right? if so PM me on there (Josh M) because i check back there more than here.
Old Aug 12, 2006 | 03:49 PM
sk8shorty012
May 6, 2009 12:10 PM
mattie_96
Nov 2, 2005 12:04 PM
SiR:Mallard
Sep 24, 2005 03:04 PM
rasinhell
13
Apr 5, 2005 12:30 PM
jaycapz
Sep 23, 2004 09:23 AM
