what sensor is this on the IM?? pics..
Is that vacuum hose hooked up to the carbon canister? It might be the EVAP purge solenoid, if that hose is hooked up to the canister. For emissions purposes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoGuy »</TD></TR><TR><TD CLASS="quote">Is that vacuum hose hooked up to the carbon canister? It might be the EVAP purge solenoid, if that hose is hooked up to the canister. For emissions purposes.</TD></TR></TABLE>
Exactly. Evap purge solenoid. If you are running OBD1, you can completely remove that whole system. Otherwise, leave it alone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_EK »</TD></TR><TR><TD CLASS="quote">nah no codes at all..just wondering if it is effecting anything?!?</TD></TR></TABLE>
It's definitely not the MAP sensor, since you live in PA, you could probably take it off, and seal up the hole.
Like Smog said, it's just part of the EVAP/emission such, not something the engine needs to run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_EK »</TD></TR><TR><TD CLASS="quote">i have a jumper harness that converts me from obd2 to obd1..so i guess im good!</TD></TR></TABLE>
Yeah, you are good to remove it if you don't have to deal with smog.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">If I wanted to take that off as well, what would be the best part to cover the hole? If there is one.</TD></TR></TABLE>
There is one line running from the solenoid to the manifold (which needs to be capped off with a vacuum cap) and another line running to the charcoal canister. The solenoid is just bolted to the manifold...there is no hole underneath it.
Someone correct me if I am wrong, but I don't recall having to do anything besides capping a vacuum source to remove the whole assembly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">There is one line running from the solenoid to the manifold (which needs to be capped off with a vacuum cap) and another line running to the charcoal canister. The solenoid is just bolted to the manifold...there is no hole underneath it.
Someone correct me if I am wrong, but I don't recall having to do anything besides capping a vacuum source to remove the whole assembly.</TD></TR></TABLE>
There is a hole underneath, that's why it's on the IM, for vacuum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">
There is a hole underneath, that's why it's on the IM, for vacuum.</TD></TR></TABLE>
You sure about that?
Thread died a couple days ago but...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">You sure about that?</TD></TR></TABLE>
Yes, I've had mine off before, and there was a hole.
Hondatypr636
Aug 22, 2011 11:19 AM
sporkcrx
17
Jul 21, 2003 08:22 PM
