Removing P/S ... Closed Loop ...
Old Aug 9, 2006 | 05:46 PM
Slomies's Avatar
Default Removing P/S ... Closed Loop ...
I want to remove my power steering, since my h23 didnt come with a p/s bracket (i bought the swap from a kid who didnt have p/s either). I want to do it closed loop as people have been talking about. I just dont know where I would loop the lines or whatever. Can someone please explain where I would do that? Also pictures would be nice if possible. Thanks!
Old Aug 9, 2006 | 05:55 PM
xamraci's Avatar
There is a barb on the power steering rack...and one off the lead from the PSing system itself...just cut off the hard line in a repairable position and then loop the system with a FUEL grade line and make sure you use appropriate clamps...I love my PSing bypass...Much love for the bypass
Old Aug 9, 2006 | 05:59 PM
xamraci's Avatar
once you remove the motor from the car...you will know exactly what I am talking about...
Old Aug 10, 2006 | 03:41 AM
Slomies's Avatar
the motor is already out ... i might just take a picture and have you point it out in the picture if you dont mind ...
Old Aug 10, 2006 | 03:46 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (95AccordVtec)
not sure if you've already seen it or if it'll help you but in the Accord FAQ there are a couple links to threads about removing power steering. It was done on an ITR but you may be able to use the links as a guide and adapt it to an Accord. I always figured if I was going to remove my PS from my Accord I would do it that way. You may want to take a look at those links, may give you some ideas.
Old Aug 10, 2006 | 04:33 AM
Slomies's Avatar
thanks. yeah i'm going to take a look at those links. also going to post a picture on here too, just in case. my motor is out for now, but going in very soon ...
Old Aug 10, 2006 | 04:34 AM
H-T Order of Merit
yep, np
yeah, it would easier to do it all now before the motor goes in, that way you have access to everything without things being in the way.
98vtec
Oct 2, 2009 10:20 AM
InvaderTrax
Dec 26, 2006 06:11 PM
BB6-213
Jan 24, 2006 08:51 PM
Hockey27925
Mar 25, 2005 10:38 AM
1.8EG-T
Aug 8, 2002 11:28 PM
