2 ga or 4 ga for a battery relocation ?
Old Aug 9, 2006 | 11:41 AM
Metal Typhoon's Avatar
Default 2 ga or 4 ga for a battery relocation ?
the local auto parts don't carry 4 ga. is 2 ga fine ?
Old Aug 9, 2006 | 12:10 PM
dopey88's Avatar
best place is to go to a car audio place. Get a good multistrand wire try to stay away from welding cable because it does have a low strand count.
Old Aug 9, 2006 | 12:30 PM
doublethink's Avatar
Default Re: 2 ga or 4 ga for a battery relocation ? (Metal Typhoon)
as said above go to a local car audio place and get a 4 AWG amp kit.
good multi strand wire and it will come with a fuse holder, which is good for saftey.
as far as the rating for the fuse itself, search on here for battery in the CRX section and youll see what other people run.
if i had to guess wither 80 or 100 amp. you could also run a breaker in there too if you wanted.
you COULD run 2 awg if you want. but it cant be thick strand AC house/commercial wiring.
Old Aug 10, 2006 | 04:11 AM
StorminMatt's Avatar
Two gauge is not only fine. It is better than 4 gauge. This is especially true due to the fact that the wire is going to be MUCH longer. A longer run means that you need a thicker wire to carry a given amount of current with a low voltage drop.
Old Aug 10, 2006 | 04:24 AM
CRX Toad's Avatar
Default Re: 2 ga or 4 ga for a battery relocation ? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">Two gauge is not only fine. It is better than 4 gauge. This is especially true due to the fact that the wire is going to be MUCH longer. A longer run means that you need a thicker wire to carry a given amount of current with a low voltage drop.</TD></TR></TABLE>
Old Aug 10, 2006 | 04:30 AM
ludesrv's Avatar
Ground the battery directly to the body in the nearest bolt hole, saves you the money of having to buy a long ground. My ground is 2 feet long, and it's about 6 inches too long.
Old Aug 10, 2006 | 04:48 AM
92integra_gs's Avatar
just go wid 2 ga
Old Aug 10, 2006 | 11:15 AM
Jacknimble's Avatar
most people I know use either 2 or 0. If you have a system run the 0. Good luck.
Old Aug 10, 2006 | 02:35 PM
mahatma's Avatar
Default Re: 2 ga or 4 ga for a battery relocation ? (Jacknimble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metal Typhoon &raquo;</TD></TR><TR><TD CLASS="quote">the local auto parts don't carry 4 ga. is 2 ga fine ?</TD></TR></TABLE>
2 &gt; 4
Old Aug 10, 2006 | 02:53 PM
efkilla's Avatar
either is fine but make sure you ground your engine bay because i relocated my battery and it wouldnt start and that was the reaoson y and get a strong battery optima beaing number one that would work best.
good luck with that man
Old Aug 10, 2006 | 02:56 PM
sam385's Avatar
2 AWG is preferable in your situation. go to a pro audio place so you get finely standed cable rather than one with few strands. 2 AWG copper has an ampacity of 100 amps. 4 AWG copper has an ampacity of 80 amps.
suds1485
Audio / Security / Video
Feb 5, 2011 08:05 AM
suds1485
Honda Civic (2001 - 2005)
Feb 3, 2011 11:41 PM
fryman
Aug 30, 2009 07:48 PM
Skeletor
Sep 6, 2007 09:50 AM
Kangolbrand
Apr 8, 2006 12:53 PM
