PGMFI help
Old Aug 9, 2006 | 09:02 AM
papa_smurf's Avatar
Default PGMFI help
i have a 89 accord i picked up for cheap it was running fine a week ago but one day i jumped in it and it just would not start. it turns over fine and i have narrowed the problem down to a lack of fuel pressure at the rail. the situation as it stands now is that it will start and run fine about half of the time, the other half it just spins but never fires up. the times that it does not start the fuel pump does not prime and there is no power to circut at the pump, so i replaced the main fuel pump relay assembly and it had no effect. im thinking it could be the ignition switch since the thing has 260k on it and the problem is intermittent, but i was hoping to get some other oppinions before i go about tearing apart the steering column. any takers?
Old Aug 9, 2006 | 02:04 PM
Enzo Speed's Avatar
Default Re: PGMFI help (papa_smurf)
I had the same symptons and it was a bad ECU.
nichole82
Mar 30, 2012 07:59 AM
markD.
10
Aug 23, 2006 06:15 PM
papa_smurf
Aug 9, 2006 03:14 PM
spettinger
May 25, 2005 11:46 AM
2camsaam
Jul 14, 2003 09:09 AM
