My 200 WHP ITR
Old Aug 8, 2006 | 05:48 PM
neo_'s Avatar
Default My 200 WHP ITR
Had my ITR tuned by John Vega of Phearable about a month back, just didn't post the results. But here it is.
No data for A/F is available, so don't ask
Full Spec list:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Block and Head:
81.25 CTR Pistons (Block Overbored .25) - Compression Ratio = 12.5:1
Buddy Club Spec 4+ Cams
Ferrea Valve Springs
Ferrea Retainers
Skunk 2 Adjustable Cam Gears
RC 370cc Injectors
AEM Fuel Presure Regulator
Ported OEM Type R Intake Manifold
Overbored OEM Type R Throttle Body to 65mm and Tappered out to 70mm
ACT Clutch
TODA 10lb Flywheel
ARP Rod Bolts
ARP Head Studs
Toda Timing Belt
Outlaw Engineering Thermal Blocking Intake Manifold Gasket
Exhaust and Intake:
Header-Tech Header (3" collector)
3" Test Pipe With Flex Section
Thermal R&D 3" Exhaust
AEM 3" Cold Air Intake
BPi Velocity Stack w/ K&N CF Filter
Moroso Oil Catch Can / Breather Kit
Interior/Exterior:
JDM Armrest Delete
JDM Honda Type R badge - 98 Spec
ITR Style E-Brake Boot
DynoJet WideBand Gauge
Autometer Oil Pressure Gauge
B&M Fuel Pressure Gauge (in engine bay)
Clear Cornors
Type R Liscence Plate Cover
JDM Power Folding Mirrors
JDM Power Folding Mirror Swtich
JDM CF Window Switch Plates
Suspension & Wheels:
H&R Sport Springs
Mugen Rear Strut Bar
Rota Slipstreams - Black
Falken Azenis RT-215 - 205/50/15
Brembo Drilled Rotors - Front
Cobalt GTsports Pads - Front and Rear
Techna Fit Stainless Steel Brake Lines - Front and Rear
Electronics:
Crome Pro ECU
OBD2 to OBD1 Conversion Harness
DynoJet Wideband
Alpine CDA 9855 Headunit
KCA-420i (iPod Interface)
3rd Gen 20gb iPod
Misc:
Mugen Valve Cover
NGK Blue Spark Plug Wires
Denso Iridium Spark Plugs
Spoon Reservoir Covers
Hasport Street Motor Mountrs
Jim Fab Torque Mounts
Short Shigter
Shifter PolyUrethane Bushings
Optional OEM Battery Tie Down
Misc Mods:
Bypassed IACV Coolant Lines
Bypassed Throttle Body Coolant Lines
Bypassed Heater Core Coolant Lines</TD></TR></TABLE>
-neo
Old Aug 8, 2006 | 06:18 PM
93allmotorcoupe's Avatar
Nice results
Old Aug 8, 2006 | 06:21 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (93allmotorcoupe)
200 is a milestone congrats
Maybe it's just wishful thinking but I think you could squeeze a few HP more maybe.
Old Aug 8, 2006 | 06:34 PM
neo_'s Avatar
Default Re: (***-assin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***-assin &raquo;</TD></TR><TR><TD CLASS="quote">200 is a milestone congrats
Maybe it's just wishful thinking but I think you could squeeze a few HP more maybe.</TD></TR></TABLE>
Thanks, my initial thought. But I'm happy with the 200 WHP mark.
Modified by _eoN at 10:45 PM 8/8/2006
Old Aug 8, 2006 | 06:40 PM
Professor15's Avatar
Let me be the first to say....thats a huge collector on that header.
Old Aug 8, 2006 | 06:41 PM
boosted k20's Avatar
Default Re: (_eoN)
good stuff. i tuned a similiar setup in a GSR motor: BC IV cams, 12.5: CR, ANR sidewinder header, OBX shortram intake on hondata making 200whp but only 132 ft-lbs. the only thing i dont like about the setup is the BCIV cams late VTEC engagement. i had to set VTEC at like 6.6K
Old Aug 8, 2006 | 06:46 PM
neo_'s Avatar
Default Re: (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">good stuff. i tuned a similiar setup in a GSR motor: BC IV cams, 12.5: CR, ANR sidewinder header, OBX shortram intake on hondata making 200whp but only 132 ft-lbs. the only thing i dont like about the setup is the BCIV cams late VTEC engagement. i had to set VTEC at like 6.6K</TD></TR></TABLE>
Pretty late indeed, mine is set at 5.4k which isn't that far off from stock.
Old Aug 8, 2006 | 06:47 PM
mtber's Avatar
Default Re: My 200 WHP ITR (_eoN)
Considering it was 104 deg F on the dyno and the intake air temps were crazy hot regardless of how many fans we used, the setup made good power.
Neo was very happy with the new drivability of the car. I hope he enjoys it & stays out of trouble
Old Aug 8, 2006 | 06:48 PM
mtber's Avatar
Default Re: My 200 WHP ITR (mtber)
For those of you that like watching dyno videos there is a dyno video on:
http://www.phearable.net/videos/
Old Aug 8, 2006 | 06:50 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Considering it was 104 deg F on the dyno and the intake air temps were crazy hot regardless of how many fans we used, the setup made good power.
Neo was very happy with the new drivability of the car. I hope he enjoys it & stays out of trouble </TD></TR></TABLE>
Indeed, having an idle on an daily driver was my priority With good gas milage to back it up
Old Aug 8, 2006 | 06:56 PM
neo_'s Avatar
BTW, that bogging indeed was a bad thermostat ground.
Anyone need a basically new distributor king distributor?
Old Aug 8, 2006 | 06:57 PM
Default Re: (_eoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _eoN &raquo;</TD></TR><TR><TD CLASS="quote">
Pretty late indeed, mine is set at 5.4k which isn't that far off from stock.</TD></TR></TABLE>
its set at 5.4? looks like around 6.4 from the dyno graphs
Old Aug 8, 2006 | 07:00 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">its set at 5.4? looks like around 6.4 from the dyno graphs</TD></TR></TABLE>
Thats what you would think with that dip there, but it is indeed at 5.4, smooth vtec transition.
Old Aug 8, 2006 | 07:30 PM
Chillinit's Avatar
Default Re: (_eoN)
Nice results. I have a similar setup with a 3" collector on my Vibrant header. I'm beginning to think that my collector is robbing me of a fuel ponies. I'm switching back to a 2 1/2" od outlet and re-dynoing. I will see if it helps. Nice setup man..
Old Aug 8, 2006 | 08:50 PM
b16ek's Avatar
Default Re: (Chillinit)
was this on pump gas?
Old Aug 8, 2006 | 09:12 PM
b19coupe's Avatar
Old Aug 8, 2006 | 09:56 PM
94rs-turbo's Avatar
looks like those buddy club cams work nice
Old Aug 9, 2006 | 01:22 AM
UncleD's Avatar
Default Re: (94rs-turbo)
Your motor and this one are neck and neck! https://honda-tech.com/zerothread/1716306
Old Aug 9, 2006 | 02:32 AM
fmrprojects's Avatar
Default Re: (clean rice)
200whp 1.8L
Old Aug 9, 2006 | 04:55 AM
neo_'s Avatar
Default Re: (b16ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ek &raquo;</TD></TR><TR><TD CLASS="quote">was this on pump gas?</TD></TR></TABLE> Yes, 93.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Your motor and this one are neck and neck! https://honda-tech.com/zerothread/1716306</TD></TR></TABLE>
True, but that doesn't look like a dynojet? So who knows how it really compares.
Old Aug 9, 2006 | 05:03 AM
1750cc's Avatar
Default Re: (_eoN)
nice built!! as well as parts!!! good choice dude..
i agree, you can probably squeeze more whp with that setup. nonetheless. GOOD JOB!
Old Aug 9, 2006 | 06:03 AM
nevets72's Avatar
nice
Old Aug 9, 2006 | 07:32 AM
Chugger's Avatar
im hoping to hit between 205-210 with my setup
c5 with ctr pistons
toda c's bc valvetrain
skunk2 cam gears
twm itb's
ericks racing header
nice numbers
Old Aug 9, 2006 | 10:01 PM
neo_'s Avatar
Default Re: (Chugger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chugger &raquo;</TD></TR><TR><TD CLASS="quote">im hoping to hit between 205-210 with my setup
c5 with ctr pistons
skunk2 cam gears
twm itb's
nice numbers</TD></TR></TABLE>
Seems acheivable.
just_dung
Northwest (Sales)
Mar 15, 2010 06:20 PM
Daz81
Oct 6, 2009 06:34 AM
RACING INTEGRATION
Sep 28, 2007 09:17 PM
NAturalEk9
Mar 25, 2007 01:50 AM
SiBirdie
Oct 13, 2001 03:31 PM
