b18 or b16?
So you're saying b16 is better? Well I still want low compression but I heard gsr head is better? I'm so confused on them! I'm leaning toward b16 tho...Unless someone can convince me to go b18???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">gsr
With GSR cams
</TD></TR></TABLE>With GSR cams
476 whp / 323 tq @ 17 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboysake »</TD></TR><TR><TD CLASS="quote">Hey I'm not sure if there is a post for this already but for an Ls motor would you rather have a Gsr head or a b16 head? Which is better?</TD></TR></TABLE>
GSR head with a 00spec CTR/ITR intake cam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC »</TD></TR><TR><TD CLASS="quote">GSR head with a 00spec CTR/ITR intake cam</TD></TR></TABLE>
good lord there is a lot of misinformation here
A GSR head flows more midrange, has a smaller combustion chamber, and will raise your compression.
A b16 head flows better up top, has a larger combustion chamber and will lower your compression.
the biggest factor though for you between these heads will be what cams your running, if its streetable and the lift on the cams. A very high lift cam with a p72 head will actually flow the same or better than a pr3 head, but if you use a more mild cam set-up then the pr3 head will flow better than the P72 up top.
My advice would be whatever head you go with, get it ported to reduce spool time and increase efficiency
there's gotta be a thread somewhere with dyno graphs of completely straight LS/VTEC builds, comparing the pr3 and p72 heads. i've been thinking of slapping a vtec head on my ls motor, but i'm not going to build it up or turbo it, or anything of the sort, i'm just gonna leave it stock. you're saying they'll give similar power, just a different power curve? and the p72 will give you more top-end but the pr3 will give you more midrange...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless »</TD></TR><TR><TD CLASS="quote"> and the p72 will give you more top-end but the pr3 will give you more midrange...?</TD></TR></TABLE>
other way around, read my post above
right, sorry.
ran a search for "lsvtec" and this thread was the very first one that came up
https://honda-tech.com/zerothread?id=1676914
I plan on running a stock gsr head...maybe building it some...but I should get new pistons and rods on a turbo ls? What's my best bet here for building ls-vt? Just parts wise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboysake »</TD></TR><TR><TD CLASS="quote">I plan on running a stock gsr head...maybe building it some...but I should get new pistons and rods on a turbo ls? What's my best bet here for building ls-vt? Just parts wise...</TD></TR></TABLE>
search
search
search
» Search Results
Your search for lsvtec returned 953 results.
search
» Search Results
