+35mm offset without rolling/flaring?
I have some 15x7 wheels with +35mm offset that i am mounting a 205\50r15 on. Do you think i can mount these on a 92 hatch without flaring or rolling the fenders?
I guess its going to be highly dependent on ride height. I dont plan on having it very low. H series motors hang pretty low as it is so I can't exactly "slam" it. Anyway, I calulated that the new tire/wheel combo should stick out about 0.905 inches farther than the oem set, assuming OEM wheel tire combo is 175\70r13 with +43mm offset, which is prolly an overestimation in offsets.
it SHOULD fit, if you lower your car, dont correct the camber, just the toe and caster (a little camber wont hurt the tires too much) and you should be fine, if not get a 195-50-15 tire instead
