Emissions testing and CR relations
Old Aug 8, 2006 | 07:42 AM
tepid1's Avatar
Default Emissions testing and CR relations
Having a lower CR in a boosted motor or even all motor application....
My stock block GSR was 10:1. I am OBD2 and need to have my computer scanned every other year. There is NO way around CT emissions testing now. So that you get an idea as to how stiff the program is now they scan the eyeball of the qualified tech that is doing the test....
My question is will I be able to pass emissions, with NO CEL, with a lower CR.... say 9.0:1. I would be converting everything back to stock including injectors, header, exhaust, ECU ect....
My best guess says that I would fail because of the stock ECU and timing issues. Generally with 1 CR point there can be a 5-7deg timing difference.
Please give me some insight on this.
Old Aug 8, 2006 | 07:46 AM
tepid1's Avatar
Default Re: Emissions testing and CR relations (tepid1)
I want to use CP pistons as well. I don't want to use anything else!
Do you think I would pass with a CP 9.8:1?
Scott53092
21
Oct 2, 2010 11:09 AM
slimjimming6688
Dec 16, 2008 06:51 AM
tepid1
Aug 8, 2006 10:00 AM
d_mina
Sep 15, 2004 09:44 AM
Damon
13
Jul 7, 2003 08:10 AM
