Emissions testing and CR relations
Old Aug 8, 2006 | 07:39 AM
tepid1's Avatar
Default Emissions testing and CR relations
Having a lower CR in a boosted motor....
My stock block GSR was 10:1. I am OBD2 and need to have my computer scanned every other year. There is NO way around CT emissions testing now. So that you get an idea as to how stiff the program is now they scan the eyeball of the qualified tech that is doing the test....
My question is will I be able to pass emissions, with NO CEL, with a lower CR.... say 9.0:1. I would be converting everything back to stock including injectors, header, exhaust, ECU ect....
My best guess says that I would fail because of the stock ECU and timing issues. Generally with 1 CR point there can be a 5-7deg timing difference.
Please give me some insight on this.
Old Aug 8, 2006 | 07:46 AM
tepid1's Avatar
Default Re: Emissions testing and CR relations (tepid1)
I want to use CP pistons as well. I don't want to use anything else!
Do you think I would pass with a CP 9.8:1?
Old Aug 8, 2006 | 08:44 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">
Where are you getting the 5-7* number? I'd say it's more like 1-2*. You should be able to pass. Are you OBDII or OBDI? Check out my thread on how to pass emissions and if you are close adjusting the timing at the dizzy could knock you to the good range.
Old Aug 8, 2006 | 10:00 AM
tepid1's Avatar
Default Re: Emissions testing and CR relations (adseguy)
I got that from this thread http://forums.evans-tuning.com...=1612....
Unless I am not understanding it correctly....
tepid1
Aug 8, 2006 07:46 AM
Kenshou Motorsports
Apr 25, 2005 10:44 AM
danny98r
Nov 30, 2004 01:20 PM
d_mina
Sep 15, 2004 09:44 AM
Damon
13
Jul 7, 2003 08:10 AM
