smaller tyres and mph?
Hi guys,
My current best times are 14.9 @ 90 mph with b16A in an eg(see mods below). This time was done on 205/50/15s dunlop street tyres, with 2.3 60fts. I would usually cross the finish @ 7k rpm in 4th. I'm goin to try some 20" slicks on 13" steelies. What kind of improvements can I look foward to?
I used these slicks on my old setup and my et improved form 16.2 to 16.00 and my 60ft from 2.5s to 2.2s. This was with a zc motor in a 1st gen teg.
If u get the launch down, good burn out in the box, and launch at like 7500 rpm, you could see 1.9's and a drop of upto a full second, but more likely .6-.7, good luck, and your rpms will increase at the line with the shorter tires
your goin from a 23inch tire to a 20inch tire... thats definately gonna make the car act like its geared deeper
i noticed a 1mph change from 25.5ish inch tires to 26inch slicks. so your gonna see a drop in 60 foot due to tire size and MOSTLY because its a slick and its sticky... and i'd say atleast 2-3mph difference, if it helps you to trap at a rpm higher than 7K... i dont know where your peak is, but i doubt its much higher than 7K. so you might pick up mph or you might not. 22inch slicks might be better for you. try the 20's and see how u run first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Orr89rocz »</TD></TR><TR><TD CLASS="quote"> 22inch slicks might be better for you. try the 20's and see how u run first</TD></TR></TABLE>
Not on a B16... Keep the 20's.
They can, but why not multiply torque even further, and run smaller diameter tires?
B16's need all the actual torque to the ground they can get.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">They can, but why not multiply torque even further, and run smaller diameter tires?
B16's need all the actual torque to the ground they can get.</TD></TR></TABLE>
Indeed... but he'll probably be looking for 5th gear. Doesn't really matter though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch »</TD></TR><TR><TD CLASS="quote">^^^ WTF i ran 22's on my B16 NA and On bottle, cut mid 1.6's with both setups. a b16 can turn 22's</TD></TR></TABLE>
How are people doing this? I had trouble getting 22"s going on my GSR.... with 14 psi in them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Bull »</TD></TR><TR><TD CLASS="quote">
How are people doing this? I had trouble getting 22"s going on my GSR.... with 14 psi in them.</TD></TR></TABLE>
He won't be anywhere near fifth gear only trapping 90mph... Even with 20" slicks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">He won't be anywhere near fifth gear only trapping 90mph... Even with 20" slicks.</TD></TR></TABLE>
Yeah. My bad on that one. You'll be looking for 5th gear at 100 mph most likely on the 20" slicks. Which is why they'll be perfect for the setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragaholic »</TD></TR><TR><TD CLASS="quote">Hi guys,
I used these slicks on my old setup and my et improved form 16.2 to 16.00 and my 60ft from 2.5s to 2.2s. This was with a zc motor in a 1st gen teg. </TD></TR></TABLE>
Are you sure you are that deep into 4th trapping at 90?
you know I might be wrong with the rpm. My teg use to trap 85 mph at redline which was 7gs with the slicks.
But I am deep into 4th gear with the 15s. It could be around mid 6s. I'll check next time for sure.
Cyber ITR
Apr 21, 2003 04:54 PM
