Mount and minor wiring question(searched)
Old Aug 7, 2006 | 07:15 PM
92civicvxhatch's Avatar
Default Mount and minor wiring question(searched)
I'm doing a b series swap in my 92 VX hatch. It's an OBD1 LS swap. I don't have the a/c bracket or the left mount that goes on the tranny(the one that bolts under the fender to the front of the tranny). Are those front pieces needed? I'm using stock 94 integra mounts and I've heard that I have to use them since I don't have Hasport mounts. I've been told that I can put 3M window sealer in the mounts to make my stock mounts solid too... so if I do that would I have to use those mounts?
Also can I just use the Integra harness... will it plug right in. I know my VX has a 5-wire o2 sensor and I would have to convert it to a 4-wire if I used it. I don't know how to do that and when I searched I couldn't find anything. Would I be able to use the Integra o2 plug if I can't use the whole Integra harness(I heard you have to use a Prelude o2 plug to convert it)?
Any help would be greatly appreciated and please no flamers!
Old Aug 7, 2006 | 07:30 PM
92redhatch's Avatar
the ac bracket and the mount that goes connected to it a not neccesary. I have solid motor mounts in my car and it barely vibrates but when i put the mount that goes under the fender my car rattles like crazy. If you ever put ac then you need the bracket but not the mount. Hope that helps you out.
Old Aug 8, 2006 | 04:53 PM
Default Re: (92redhatch)
That helps a little but only if that 3M trick works which I still don't know. Anyone else?
Old Aug 8, 2006 | 05:13 PM
Sleepy_Red_hatch's Avatar
Default Re: (92civicvxhatch)
ehhh i think i'd stick with getting the mounts if i where you. use the AC mount that came with the VX?
Old Aug 8, 2006 | 11:58 PM
92_VX_EG's Avatar
Default Re: Mount and minor wiring question(searched) (92civicvxhatch)
I've heard of the 3M way but the people that I know that did that still used the A/C and tranny bracket.
92civicvxhatch
Aug 9, 2006 07:55 AM
92CiviC4dr
Mar 2, 2006 08:04 AM
LSEGHATCH
Jan 31, 2005 07:05 PM
CW96
Dec 6, 2003 03:58 PM
2muchPSI
Oct 15, 2002 07:42 AM
