B series swap question
Mount and wiring question(searched)
I'm doing a b series swap in my 92 VX hatch. It's an OBD1 LS swap. I don't have the a/c bracket or the left mount that goes on the tranny(the one that bolts under the fender to the front of the tranny). Are those front pieces needed? I'm using stock 94 integra mounts and I've heard that I have to use them since I don't have Hasport mounts.
Also can I just use the Integra harness... will it plug right in. I know my VX has a 5-wire o2 sensor and I would have to convert it to a 4-wire if I used it. I don't know how to do that and when I searched I couldn't find anything. Would I be able to use the Integra o2 plug if I can't use the whole Integra harness(I heard you have to use a Prelude o2 plug to convert it)?
Any help would be greatly appreciated and please no flamers!
Modified by 92civicvxhatch at 8:11 PM 8/7/2006
Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">the ac bracket is not needed. The mount is not needed. But if you want ac then you need the bracket.</TD></TR></TABLE>
hell yeah you need them. the motor is gonna rock like crazy and destroy all the other mounts. get some poly urthane inserts. for the harness, just use the integra and repin the os wires going into the ecu
Hondurr
08-10-2009 11:13 PM
92civicvxhatch
08-08-2006 11:58 PM
