Civic Si Bogs when letting out clutch
Old Aug 7, 2006 | 12:46 PM
steveo2000em1's Avatar
Default Civic Si Bogs when letting out clutch - SOLVED
*** SOLVED ****
Replaced the spark plugs, wires, cap and rotor. Runs like a champ again!
Thanks for all the help HT!
The car worked fine until today. I noticed that when you let out the clutch today the car would bog. When in neutral the engine revs fine. This is what leads me to believe that is clutch related.
I appreciate any help.
Modified by steveo2000em1 at 4:41 AM 8/9/2006
Modified by steveo2000em1 at 4:43 AM 8/9/2006
Old Aug 7, 2006 | 01:54 PM
Does this sound like a bad clutch to anybody?
Old Aug 7, 2006 | 01:56 PM
-Gary-'s Avatar
Default Re: (steveo2000em1)
How does it do after the clutch is engauged?
Does it bog under a load or just when the clutch lets out.
I may not have your answers but I'll ask the right questions.
Shake and Bake's Avatar
are you giving it enough gas when you pull out of first?
hmtcrxsir's Avatar
what you mean it bogs? you mean it makes a sound? like the throw out bearing?
Old Aug 7, 2006 | 02:04 PM
SiYouLater's Avatar
Default Re: (hmtcrxsir)
bog means to be slowed down. So it will be like a little jerk.
Old Aug 7, 2006 | 02:07 PM
Default Re: (AllmotaBseries)
The engine makes a low pitched bog sound. It sounds like it may die unless you "feather" the gas.
When in neutral the engine will rev fine throught the powerband. If you were to hit the gas while at idle the engine will NOT bog.
I'm used to my car as I've had it for about a year and a half. I just noticed today that when letting out the clutch (just like I normally used to) the engine felt like it was going to die if I didn't give it more gas.
I've driven stick shift cars before but I never had a clutch go out. I don't know if this is a warning sign of what is to come when a clutch starts to go bad.
The car is bogging from 1st to 2nd and a little bit 2nd to 3rd.
Let me know if I'm being descriptive enough...
Old Aug 7, 2006 | 03:14 PM
E46Kid's Avatar
Couple things i would do:
Check Your Oil
Check Your Spark Plugs
Check Distributer, Cap and rotor.
Im guessing no cels?
Old Aug 8, 2006 | 02:11 AM
hmtcrxsir's Avatar
Default Re: (Em1Kid)
i think your clutch might be going. I had a problem similar to yours. I open the clutch and found only half of the clutch was still intact.
Old Aug 8, 2006 | 03:22 AM
Ok, I just drove the Si to work today (about an hour drive). It will kinda sputter out of first gear and then a little bit when you're shifting into second gear. On the highway at 70 the whole way I had no problems. Downshifting (from 5th to 4th) didn't produce a sputter but then again the RPM are around 3500 - 4000 so I could see why you wouldn't have a sputter or bog.
The car definately still has power and I want to find out what the problem is. I think it's the clutch.
Do you think maybe (and this is a longshot) that I may have a bad tank of gas that could do this?
Old Aug 8, 2006 | 03:50 AM
UK_EG's Avatar
Drive along in a high gear (3rd,4th or 5th) at about 3000rpm, keep the throttle pedal postion constant and press the clutch in and then release it fairly fast. If the revs rise with out the car speeding up then the clutch is slipping and is worn out. If the cluctch grabs the car will jolt and carry on driving at constant rpm.
If you do this going up hill it should very obvious if the clutch start to slip as the car will slow down as the revs rise!
This dosnt sound like a clutch problem to me.
Old Aug 9, 2006 | 03:42 AM
Solved - See the edited 1st post by me! Thanks again.
sageuvagony
Jul 16, 2007 12:30 AM
fauxhawkid
Dec 25, 2005 05:01 PM
neopheus
Mar 13, 2005 10:20 PM
Project X
Feb 24, 2004 06:28 AM
Wave
Sep 20, 2003 04:50 PM
