type r timing belt question...
Old Aug 7, 2006 | 12:19 PM
beaneg6's Avatar
Default type r timing belt question...
i have a 96 jdm type r head with a usdm type r bottom end, im unsure of the year of the bottom end but it has to be what 98 or newer i bought a brand new oem timing belt 125 teeth and it does not fit, it looks like its off by 1 tooth, are there different timing belts? or what wrong here?
Old Aug 7, 2006 | 12:30 PM
typer_696's Avatar
Default Re: type r timing belt question... (beaneg6)
You are not timing it right. They are the same.
Old Aug 7, 2006 | 12:31 PM
beaneg6's Avatar
Default Re: type r timing belt question... (typer_696)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_696 &raquo;</TD></TR><TR><TD CLASS="quote">You are not timing it right. They are the same.</TD></TR></TABLE>
i am damn sure that i am timing it right...oem type r oil pump w/ a 22t water pump, timing is perfect,
Old Aug 7, 2006 | 01:16 PM
Padawan's Avatar
Darth ModerVader
If the timing is perfect, what is the issue?
Old Aug 7, 2006 | 02:21 PM
beaneg6's Avatar
Default Re: type r timing belt question... (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If the timing is perfect, what is the issue? </TD></TR></TABLE>\
timing is perfect, the issue is the belt does not fit
1990_integra_DA9
Aug 3, 2007 02:24 AM
boomersz
Mar 4, 2007 07:55 AM
bart2546
13
Dec 30, 2006 10:51 AM
sslude
Jun 25, 2004 07:53 AM
