88' civic having distributer problems
Old Aug 7, 2006 | 09:37 AM
stanman309's Avatar
Default 88' civic having distributer problems
I just recently replaced the distributer because the old ones rotors nut was stripped and my step dad tried drilling it out and the bolt was too big. Basically when i turn it it makes a noise like the pistons arnt moving its just 1 steady sound. i have it on my camera phone but i dont know how to upload it on this. IT has something to do with the distributer because it worked before that. Thanks alot
Stan Keech
Old Aug 7, 2006 | 09:57 AM
Redline130's Avatar
Default Re: 88' civic having distributer problems (stanman309)
Are the distributor plugs nice and tight? Is the battery ok? Did you remove/unplug anything else?
Old Aug 7, 2006 | 09:26 PM
stanman309's Avatar
Default Re: 88' civic having distributer problems (Redline130)
everything seems to be in check. is there anyway to upload videos on the forum cause i have a video that was taken on my phone that might narrow down the possibilities.
i failed to mention i bought a brand new distributer, distributer cap and rotor.
the battery gives plenty of juice to turn over the car but it wont start. Basically what happens is i turn the key and it makes a single hum noise and keeps humming as long as i have the key turned. you know how when you start a car the pistons start moving and gives it a distinct noise. its just a flat one note' noise
Old Aug 7, 2006 | 10:57 PM
Paxil4x4's Avatar
Wonder if the timing belt snapped or came off
Old Aug 8, 2006 | 09:19 AM
gp70hs's Avatar
Default Re: 88' civic having distributer problems (packthis)
When you try to start the car, does the crankshaft turn? I think you might have bumped the wire that goes to the starter solenoid, it's right below the distributor. It is a blade wire that plugs into a wire to the starter solenoid. If it's loose, then nothing's happening, which is why it's so quiet.
gavingt
Jun 22, 2017 09:28 PM
bigandy90
Jan 2, 2008 09:35 PM
juice91si
13
Feb 17, 2006 10:12 PM
IntegraFroggie
Jun 24, 2004 05:49 PM
ridnmyhonda
Jan 8, 2003 07:50 AM
