crankshaft sensor different on gsr block?
Old Aug 7, 2006 | 08:13 AM
Caucasian-Invasion's Avatar
Default crankshaft sensor different on gsr block?
I had a b16a from japan in my 96 ex and pulled it out to swap blocks with a b18c1 with type-r pistons, during this build i noticed a couple differences but the most disturbing was the fact that the b16 had a sensor next to the bottom gear for the T-belt thats behind the crank pulley. The problem part is how theres no place to mount said sensor on the b18 block and i dont know if i need it, im guessing if its there and was plugged in, that it was there for a reason anyone know anything here that may help shed some light?
Old Aug 7, 2006 | 10:55 AM
v4lu3s's Avatar
RTFM
obd2 requires teh CKF, Crank Fluctuation sensor. It will be found on almost all 96 up B and D series blocks. It sits on the oil pump, which is slightly diff from obd2 to 1 to account for the mounting of the sensor as well as sprocket with the pickup.
Old Aug 7, 2006 | 07:34 PM
Default Re: (v4lu3s)
so, is my solution to get a different ecu? and leave that sensor out, (its obvious i have to leave it out, there's no where for it to go)
Old Aug 8, 2006 | 02:24 PM
WhiteNess's Avatar
Default Re: (Caucasian-Invasion)
Yea my friend has a gsr motor in his 2000 si....same problem as u....he throws a code for cfk since he is running the si computer.....your car will run fine but will throw a CEL......any solutions on how to solve this????
Old Aug 8, 2006 | 03:09 PM
v4lu3s's Avatar
RTFM
to solve it the way i know to do it is put the ob2 oil pump and lower timing sprocket on and then install teh sensor.
stealth_EK4
May 6, 2005 11:40 AM
Greasemonkey
Oct 19, 2004 03:22 PM
Huee
Mar 1, 2004 12:53 PM
rtype11
Nov 9, 2001 10:05 AM
