What is this plug/wire for?
Single wire connector, O2S, engine temp guage, knock sensor, AC Compressor power, been awhile since I worked on an older Honda, looks like a Toyota plug though, anymore ideas. Radiator fan power, ground goes to frame. Has to go in the engine bay?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">It is an O2 wire extender.</TD></TR></TABLE>
the usually come with dc header/s and some other companies. since the o2 bung is located on the collecter instead of on one of the runners the o2 needs to be extended. that way you dont need to cut, extent, solder... just plug and play
dropd4door
Dec 27, 2004 09:53 PM
