missing wire
Old Oct 19, 2011 | 07:51 AM
1992honda's Avatar
Default missing wire
After I replaced the radiator I pluged in the condencer fan and noticed that the top plug was missing a wire.this plug ha a single hole in it. Should this hole have a wire coming out of it??? Maybe a ground or is it a blank?
Thanks
Old Oct 19, 2011 | 08:19 AM
techtalk's Avatar
Default Re: missing wire
1992Honda,
If I remember correctly, the plug only contains one wire. That other "hole" in the plug is normal.
If you look at this '92 Accord condenser diagram, you'll see that the plug only contains one wire as well:
*diagram courtesy of hondapartsnow.com; all rights reserved
Old Oct 20, 2011 | 07:41 AM
1992honda's Avatar
thanks
Old Oct 21, 2011 | 04:42 PM
Lost Again's Avatar
Check to be sure BOTH fans run when the temp gets warm or when the AC is on-assuming you have a working ac system.
ivan93egreppin210
Jun 19, 2010 02:15 PM
_kiid
Texas -OK -LA (Sales)
Sep 13, 2009 04:39 PM
Nicaraguense13
Jul 28, 2008 12:21 PM
pro547
Feb 20, 2005 02:32 PM
labatt50
Jul 30, 2004 03:25 PM
