whats the part Number for the 26mm si sway bar?
Old Aug 7, 2006 | 12:27 AM
Bullitt's Avatar
Default whats the part Number for the 26mm si sway bar?
I need the part number for the 26mm front sway bar from the 99-00 Civic Si. I want to ask my local dealer if they can special order this part for me here in Germany. The problem is that they only have access to these parts if you have the part Number. And this part is not in the German EPC
I also need the numbers for the bushings and U clamps that hold the bushings.
thanks
Old Aug 7, 2006 | 12:49 AM
umop-apisdn's Avatar
Default Re: whats the part Number for the 26mm si sway bar? (Bullitt)
SPRING, FR. STABILIZER (26MM) 51300-S04-N01 QTY 1
BUSH, STABILIZER HOLDER (26MM) 51306-S04-N01 QTY 2
HOLDER, R. FR. STABILIZER 51308-SR3-000 QTY 2
Old Aug 7, 2006 | 02:02 AM
Bullitt's Avatar
Default Re: whats the part Number for the 26mm si sway bar? (umop-apisdn)
Awsome, thanks for the fast response
Old Aug 7, 2006 | 05:14 AM
sicones's Avatar
you know you also need Si front lower control arms right??
Old Aug 7, 2006 | 07:58 AM
BlueIntegraBoy's Avatar
Default Re: whats the part Number for the 26mm si sway bar? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">you know you also need Si front lower control arms right??</TD></TR></TABLE>
And strut forks
PARADOX_sf
Suspension & Brakes
19
Jan 10, 2007 01:40 PM
Malakai
Jul 9, 2006 01:39 PM
Jaydeep
Jan 7, 2005 08:09 PM
deeksmooth
Dec 9, 2003 03:56 PM
Mr. Choi
Aug 5, 2003 01:33 PM
