Help on RE-ROUTE HOOD RELEASE CABLE
Old Aug 6, 2006 | 10:13 PM
vtec25's Avatar
Default Help on RE-ROUTE HOOD RELEASE CABLE
I want to re-route the hood cable but not quite sure where to begin.
Any tips,advice,web sites would be grateful.
Old Aug 6, 2006 | 10:54 PM
alacard's Avatar
Default Re: Help on RE-ROUTE HOOD RELEASE CABLE (vtec25)
bump because i broke mine..and i want to reroute it when i fix it
Old Aug 6, 2006 | 11:06 PM
RCautoworks's Avatar
Default Re: Help on RE-ROUTE HOOD RELEASE CABLE (alacard)
Why would you want to re-route it ?
Old Aug 6, 2006 | 11:07 PM
alacard's Avatar
Default Re: Help on RE-ROUTE HOOD RELEASE CABLE (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec25 &raquo;</TD></TR><TR><TD CLASS="quote">I want to re-route the hood cable but not quite sure where to begin.
Any tips,advice,web sites would be grateful.</TD></TR></TABLE>
just that much more trouble for thieves.
Old Aug 6, 2006 | 11:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">
just that much more trouble for thieves.</TD></TR></TABLE>
Its hidden under the wheel well, pretty hard to began with. If someone breaks into your car I would worry more about them steeling the whole car rather then popping the hood and taking parts.
If a thief wants to look under the hood, they don't have to get inside the car.
Old Aug 6, 2006 | 11:51 PM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">I would worry more about them steeling the whole car rather then popping the hood and taking parts.</TD></TR></TABLE>
he may be talking about a thief popping the hood to de-activate his alarm system, although if they wanted to they could still usually disconnect your alarm from inside the vehicle... where exactly were you planning on re-routing the cable to? i might be able to assist you (i re-routed mine on one of my old eg's).
Old Aug 7, 2006 | 12:10 AM
FalkenSiR's Avatar
Default Re: Help on RE-ROUTE HOOD RELEASE CABLE (thahuhstunna)
there is a thread on this, seen it some time ago. Just gotta search
Old Aug 7, 2006 | 03:06 AM
R1Motorsports.com's Avatar
Default Re: Help on RE-ROUTE HOOD RELEASE CABLE (fast95eg8)
Are you talking about re-routing the entire cable assy. or just the moving the latch under the dash? If it's the cable your wanting to re-route, I'd say it's already hard enough to get too as it is.
Old Aug 7, 2006 | 04:08 AM
slowSOHCvtec's Avatar
Default Re: Help on RE-ROUTE HOOD RELEASE CABLE (R1Motorsports.com)
There is a link somewhere on here about how to reroute it let me see if i can search and find it
Old Aug 7, 2006 | 05:25 AM
Syndacate's Avatar
It's completely useless... What's the difference between him popping the hood w/ a coat hanger through the fender and pulling off the negative term, or breaking the window, pulling the hood latch, and pulling the negative terminal off - the alarm IF equiped with a shock sensor will sound for what, 10 seconds? before they pull the plug? Yea, basically, the best thing you can do alarm wise is install and hide a backup battery for the alarm system so it could work independently of the battery, that + a shock sensor will mean the alarm will probably go off and stay on....by the time they disable the battery and hte alarm is still on they might decide to run away...but probably not, you'll need a second siren as well because in that 30 seconds they'll also hav ethe wires cut to the siren....
In order to secure your car, a cable re-rout isn't going to do jack ****, you'll need an alarm system w/ a window shock sensor, starter kill relay, duel sirens (hard to get to), and a backup battery (hard to get to)..
Old Aug 7, 2006 | 06:42 AM
Sleepy_Red_hatch's Avatar
Default Re: (Syndacate)
the cable is way easy to get to, i rerouted it inside the engine bay
gofastgokart99
Nov 22, 2007 09:19 AM
dopefeen
Oct 14, 2007 01:04 PM
user 98292739
Sep 5, 2006 08:12 AM
madmanmulligan
May 21, 2006 09:32 AM
noob with an RS
Jan 10, 2005 01:24 AM
