b16... bad ground?
Old Aug 6, 2006 | 07:26 PM
1_slow_crx's Avatar
Default b16... bad ground?
so i dont know how i did it but i fucked the battery **** up...
i had just put on the intake and drop a wrench on top of the battery making it touch both the positive and negative terminals. now i cant figure out what to do. i can get the car to peep when the door is open and the clock to show. but when i try to crank it it sparks on the negative terminals...
wtf should i do?
Old Aug 6, 2006 | 07:58 PM
hybridmiklo's Avatar
Default Re: b16... bad ground? (1_slow_crx)
Check the fuse under the hood. I think it's a 50amp. It could have blown. The fusebox is located on the passenger side of the engine bay.
Old Aug 6, 2006 | 09:31 PM
1_slow_crx's Avatar
Default Re: b16... bad ground? (hybridmiklo)
nope i changed all of them...
one 50, one 50 and a 60 for thebattery........NOTHINg..
what else could it be? also when i get it going.. if i turn the lights on it makes it pop..
i think i have a short somewhere?!! wtf
Old Aug 6, 2006 | 11:15 PM
Redline130's Avatar
Try another battery and see if that helps. Did you check all the fuses under the dash as well? Are your battery terminals on tight?
Old Aug 7, 2006 | 05:14 AM
1_slow_crx's Avatar
Default Re: b16... bad ground? (Redline130)
yes to all.
hmmm
KingofKingz80
19
Sep 16, 2013 06:18 AM
GSR_hatch936
10
Feb 25, 2008 11:49 AM
Tip14
Dec 27, 2007 01:13 PM
R-81DC2
Jun 5, 2007 09:21 AM
coot_er
May 19, 2004 05:26 PM
