Finding TDC on sohc
Old Aug 6, 2006 | 05:19 PM
Mr.Death's Avatar
Default Finding TDC on sohc
I took a look at my crank pulley and there are no marks for finding TDC. I guess I'll have to find TDC the old fashioned way by using a long screwdriver in cylinder #1 and turning the crank by way of ratchet until it reaches the top of it's stroke and determine weather or not it's on it's compression stroke by looking at the dizzy to see if the rotor is pointing to spark plug one. Sounds right or is there a better way of finding TDC on a sohc?
Old Aug 6, 2006 | 05:20 PM
92integra_gs's Avatar
is your timing belt still intact wid the cylinder head... cuz you can just do it that way too...
Old Aug 6, 2006 | 05:36 PM
Mr.Death's Avatar
Default Re: (92integra_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">is your timing belt still intact wid the cylinder head... cuz you can just do it that way too...</TD></TR></TABLE>
THe motor is still togeather.
Old Aug 6, 2006 | 05:48 PM
https://honda-tech.com/zerothread?id=1713354
here read this.. this one was just a thread created today... HTH
Old Aug 6, 2006 | 06:42 PM
bluez6's Avatar
where do you download the helms manual at?
Old Aug 6, 2006 | 07:15 PM
SIred91's Avatar
Rainman
Default Re: (bluez6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluez6 &raquo;</TD></TR><TR><TD CLASS="quote">where do you download the helms manual at?</TD></TR></TABLE>
I too would like to know
Old Aug 6, 2006 | 09:12 PM
RockWolf's Avatar
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluez6 &raquo;</TD></TR><TR><TD CLASS="quote">where do you download the helms manual at?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
I too would like to know</TD></TR></TABLE>
Ditto
Old Feb 2, 2009 | 11:23 AM
jdm602's Avatar
Default Re: Finding TDC on sohc
tdc on the cam is when the arrow is pointing straight up*
tdc on the rotating assembly are based on the lines on the crank timing gear (not the pulley) and the oil pump on the block. tdc is when the lines are matched up.
opps, sorry mods, just saw how old the post it. haha.
Old Feb 2, 2009 | 11:25 AM
turbojdmhatch's Avatar
tdc will say "UP" on the cam gear
Old Feb 2, 2009 | 03:02 PM
the_woodcutter's Avatar
with the cylinder head off wouldn't the piston be flush to the top of the block? oops, wait a second...at zero compression right? heck, i dunno...
Old Feb 2, 2009 | 08:26 PM
jz98ctr's Avatar
sheesh....if the engine is still together...try this "old-school" trick...
#1...pull the #1 spark plug wire out and #1 spark plug out of it's hole.
#2...get into car and put key in ignition.
#3...very quickly tap the key to the start position repeatedly and listen (or have a helper) listen for a loud CHUFF come out of the #1 cylinder bore. When you hear that noise...you are on compression stroke.
#4...you're welcome
Old Feb 3, 2009 | 06:28 AM
apekd's Avatar
First thing i would do is(with the belt on) turbo the crank till the cam gear is pointing the words UP, well, up. then pull the belt off, pull the #1 plug and move the crankshaft. you then will see if it is TDC or not.
yoffer
17
Feb 25, 2008 08:33 PM
dturbo
Jun 25, 2007 01:41 PM
silentbeatz
Aug 21, 2005 10:38 AM
Crit
Aug 23, 2004 10:50 AM
tangb2023
Jul 14, 2003 11:36 PM
