2000 GSR seats in 96 Ek Hatchback??
Old Aug 6, 2006 | 04:22 PM
Elite Hatch's Avatar
Default 2000 GSR seats in 96 Ek Hatchback??
If I remember correctly 2000 GSR rear seats will fit in replacement of the back seats in a 96 civic hatchback. Anyone know for sure?
Old Aug 6, 2006 | 04:43 PM
teamvirus's Avatar
My car breaks a lot!
Default Re: 2000 GSR seats in 96 Ek Hatchback?? (Elite Hatch)
i dont think so gsr seats fit in eg not ek...dont quote me on that tho
Old Aug 6, 2006 | 04:59 PM
SkyliteCustomz's Avatar
Default Re: 2000 GSR seats in 96 Ek Hatchback?? (teamvirus)
yea i think so..only from the 4 doors will fit snug i think...
Old Aug 6, 2006 | 05:54 PM
IT'S ME DAVID's Avatar
NooB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus &raquo;</TD></TR><TR><TD CLASS="quote">i dont think so gsr seats fit in eg not ek...dont quote me on that tho </TD></TR></TABLE>
i got eg seat in my 96 ek and they fit snug as in perfect just the bottom little barckets dont go in the hole.
Old Aug 7, 2006 | 04:01 AM
Default Re: 2000 GSR seats in 96 Ek Hatchback?? (IT'S ME DAVID)
Hmm...so we thinkin they will fit or not fit. I am confused now
Old Aug 7, 2006 | 08:27 AM
Anyone know. Im tryin to buy these tonight but if they dont fit I dont want to buy them?
Old Aug 7, 2006 | 08:33 AM
6SPD_EK's Avatar
search been done before with some space between the 2 sides & maybe small gap between the bench & the back
the best possible fit would be 4-dr integra (LS/GS/GSR/ITR) bottoms & 2dr backs
search "archive topics"
limit to "'92-00 Civic/Del Sol" forum
search "rear seats"
GSR coupe will fit the same as integra, & type r so you don't want to limit your search by using "GSR"
Old Aug 7, 2006 | 09:45 AM
uilani158's Avatar
Default Re: 2000 GSR seats in 96 Ek Hatchback?? (_adirondackR_)
_adirondackR_ is correct. If you dont use 4dr bottoms and 2dr backs there will be a gap on both sides of the bottom seat and also a gap between the bottom and backs. I've leared this from experience, the gap is VERY noticible.
Old Aug 7, 2006 | 09:57 AM
Almostlude's Avatar
I had DC2 Leathers in my EK. There is a gap that is left on the sides of the seat ( didn't think it was that bad, but that's all relative). Plus you need to reverse the center bracket (it's a lot easier done that said).
Old Aug 7, 2006 | 10:19 AM
pkdog167's Avatar
Default Re: (Almostlude)
integra 2dr top + integra 4dr bottom will be the perfect fit :D or it'll be a gap.
Old Aug 7, 2006 | 11:13 AM
dnaazn326's Avatar
The seats will fit ok with slight modifications... This is what i did.
2 door GSR Leather seats front and back.
Rear bottom cushion, put a used towel underneath and it will raise it up to the seat backs.
Side will have a gap, however you can just purchase some black foam material or carpet and stuff it down the side and it looks good!
Seat backs, i suggest stripping the seat paddings and use the original metal frame from your hatch. this should fit with out any problems!
God bless,
Danny
Old Aug 7, 2006 | 01:15 PM
FGride's Avatar
you have to change out the seat rails to getr them to bolt in correctly w/ all four bolt or else only three line up
Old Aug 7, 2006 | 01:46 PM
Default Re: 2000 GSR seats in 96 Ek Hatchback?? (batmanEK)
Thanks everyone for all the insight. Now I know what I am getting into. The fronts no issue changing brakets. As for the rears for now I will set it up like said above and get carpet or leather on each side of some foam until I can find some four door bottoms.
Old Aug 7, 2006 | 01:47 PM
Default Re: 2000 GSR seats in 96 Ek Hatchback?? (dnaazn326)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnaazn326 &raquo;</TD></TR><TR><TD CLASS="quote">
God bless,
Danny</TD></TR></TABLE>
What do you mean by stripping the seat paddings?
Old Aug 17, 2006 | 08:25 AM
dnaazn326's Avatar
Stripping the seat paddings basically means that you would take out all those round clips on the back of your seat by using 2 pliers. carefully take off the padding and do the same for the integra ones. Be really careful with the metal frames! They are ultra sharp! Both my friend and I got a cut from the sharp edges!
When you have both paddings off, just put the GSR Seats in on the civic metal frame. Use zip ties where there used to be round clips. you shouldn't have any problems.
Old Aug 17, 2006 | 09:43 AM
Sloshy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnaazn326 &raquo;</TD></TR><TR><TD CLASS="quote">Stripping the seat paddings basically means that you would take out all those round clips on the back of your seat by using 2 pliers. carefully take off the padding and do the same for the integra ones. Be really careful with the metal frames! They are ultra sharp! Both my friend and I got a cut from the sharp edges!
When you have both paddings off, just put the GSR Seats in on the civic metal frame. Use zip ties where there used to be round clips. you shouldn't have any problems. </TD></TR></TABLE>
you have any pictures or a full walk through on this man..
Old Aug 17, 2006 | 03:29 PM
Default Re: 2000 GSR seats in 96 Ek Hatchback?? (hatch-E-vanish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish &raquo;</TD></TR><TR><TD CLASS="quote">you have any pictures or a full walk through on this man..</TD></TR></TABLE>
That would be nice but I have my doubts
Old Aug 23, 2006 | 01:40 AM
juss get a DC 4door bottom portion of the back seat..and a 2 door upper portion of the back seat..and u will be set
Old Aug 23, 2006 | 02:12 AM
EK SQUAD 425's Avatar
im pretty sure it will work i got 2 gray gsr leather fronts...only 3 bolts brack up... 1 doesnt.
FRKWOO
Jan 10, 2009 07:30 AM
ballerchild
Feb 20, 2007 11:46 PM
blkeksedan
Feb 19, 2007 04:08 PM
twofive
Dec 9, 2005 06:20 AM
civiccivic
Sep 27, 2002 08:03 PM
