Primary O2 sensor causing cat. converter to throw CEL?
Old Aug 6, 2006 | 12:45 PM
DFW's Avatar
DFW
Default Primary O2 sensor causing cat. converter to throw CEL?
I have a CEL for bank1 o2 sensor and the catalytic converter. Would a bad primary o2 sensor also cause the cat to throw a CEl also?
Old Aug 6, 2006 | 02:46 PM
DFW's Avatar
DFW
Default Re: Primary O2 sensor causing cat. converter to throw CEL? (DFW)
Anyone?
Old Sep 20, 2006 | 10:13 AM
DFW's Avatar
DFW
bump...
Old Sep 20, 2006 | 10:34 AM
Relic1's Avatar
primary O2 will cause the engine to run rich.
which may set the secondary O2 code for cat converter.
If you've been messing with the car lately, more than likely you have a wiring issue which cut the power or ground to the O2s.
If the car is stock or not messed with in the last couple months then you will be looking at a new O2 for sure.
Old Sep 20, 2006 | 10:37 AM
DFW's Avatar
DFW
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">primary O2 will cause the engine to run rich.
If the car is stock or not messed with in the last couple months then you will be looking at a new O2 for sure.</TD></TR></TABLE>
I bought the car with a fuked up cluster so after I got a new one, there was a CEL so it was there before I bought it. But the motor is stock.
How many MPG should I be getting in a stock dx? I beilive I'm getting around 30-31mpg that last time I checked with the CEL.
Old Sep 20, 2006 | 10:54 AM
instructor74's Avatar
Default Re: (DFW)
If you had a non working O2 sensor you would be seeing somewhere in the mid to low teens (17-18 mpg). It sounds like you just have a wiring problem. Good luck I would look more to there being a problem with the second O2
Old Sep 20, 2006 | 11:01 AM
DFW's Avatar
DFW
Default Re: (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">If you had a non working O2 sensor you would be seeing somewhere in the mid to low teens (17-18 mpg). It sounds like you just have a wiring problem. Good luck I would look more to there being a problem with the second O2 </TD></TR></TABLE>
When I went to get it check they said it was "bank 1 sensor" which I was told is the primary one, so I don't see how it could be the sencondary.
I'll check the wires again when I get home from work.
sickofitall1113
Jun 11, 2007 10:20 AM
smooz EK
12
Nov 12, 2003 10:07 AM
fredtoast
May 9, 2003 05:41 PM
R-1303
Jun 24, 2002 07:00 PM
degradated
Nov 5, 2001 02:57 AM
