HOLE in my B16A block?
Old Aug 6, 2006 | 12:25 PM
CRXcamaro's Avatar
Default HOLE in my B16A block?
There is a perfectly machined hole in the back of my b16 block, right below the intake manifold. The hole is about double the size of a quarter, when I got the car there was nothing in there. What should be there?
Old Aug 6, 2006 | 12:32 PM
jdmcrx90's Avatar
prob. your oil pressure sending unit.
Old Aug 6, 2006 | 12:37 PM
CRXcamaro's Avatar
Default Re: (jdmcrx90)
I could be wrong, but I believe when looking at it the oil preesure unit is to the left. Also, that hole is threaded, this hole is perfectly smooth. Almost as if anything went there it would have to be a freeze plug or a rubber plug..
Old Aug 6, 2006 | 02:01 PM
Tippyman's Avatar
Connecting rod FTW.
J/K, I have no idea. BUMP 4 u.
Old Aug 6, 2006 | 02:17 PM
crxpwr1's Avatar
Default Re: (Tippyman)
Can ya take a pic I have a b16 sitting out side but I dont think I have a hole in the block
Old Aug 6, 2006 | 02:35 PM
StorminMatt's Avatar
Default Re: (crxpwr1)
Is the hole threaded? If so, there is supposed to be a screw-in plug for that hole. It screws in with a large allen wrench. Also, there is a non-threaded hole on the back of the motor for the PCV system. The oil separator box uses this hole.
Old Aug 6, 2006 | 03:26 PM
E_F_9's Avatar
Default Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">Is the hole threaded? If so, there is supposed to be a screw-in plug for that hole. It screws in with a large allen wrench. Also, there is a non-threaded hole on the back of the motor for the PCV system. The oil separator box uses this hole.</TD></TR></TABLE>
Old Aug 6, 2006 | 04:07 PM
Ronster's Avatar
Default Re: (MaD_VTAK)
its not where the oil filter screws in is it?
Old Aug 6, 2006 | 04:52 PM
CRXcamaro's Avatar
Yes it is the pcv box, thanks alot. I have spare parts from a D16 the guy gave me and thought the little black box was from that. Again, thanks!!
stat3ofm1nd
Welding / Fabrication
13
Oct 15, 2012 10:27 AM
tangerinebeast
Mar 29, 2011 11:56 AM
gATOr65
Jul 4, 2008 05:21 PM
INCNTRL4
10
Jun 29, 2006 07:32 PM
PM-Performance
Dec 8, 2003 10:29 AM
