4gen speaker help
Old Aug 6, 2006 | 07:22 AM
msinsky14's Avatar
Default 4gen speaker help
my passenger side speakers only work when I hit a bump and then turn off when I hit another bump or turn a corner hard, and my rear speakers do not work at all. I have an aftermarket stereo which I believe wasnt wired correctly. is there a wiring diagram for all the car speakers and how do I check the wiring for the two rear speakers?
Old Aug 6, 2006 | 07:57 AM
Speedra500's Avatar
Default Re: 4gen speaker help (msinsky14)
it is probably a bad connection on the speakers, I would inspect the connection to verify it is making good contact
Old Aug 6, 2006 | 11:44 AM
msinsky14's Avatar
Default Re: 4gen speaker help (Speedra500)
so just take the door panels out and check the speakers? or check the stereo? b/c it doesnt make sense that it would happen to the rear speakers as well, thats why I think its the stereo
Old Aug 6, 2006 | 02:12 PM
Slatelude's Avatar
1. I dunno about the rear speakers...thats pretty general, I'd check the connections at the speakers first and then go from there (start easy--->progress to the harder to find/work on)
2. the front one is probably touching the poles on the speaker to the door panel when you hit a bump and knocking it off whenever you hit again. I've had this problem in my cars and my bro's 'teg. Just remove the door panel and bend the tabs away from the door (elec. tape for extra security if ya wanna).
GOOD LUCK !!!
k
Old Aug 6, 2006 | 03:41 PM
TurboBA8's Avatar
Default Re: 4gen speaker help (Slatelude)
it is most likely the connection at the head unit if you have 3 speakers not working. it is a good idea to start simple and just look at the speakers, then go to the head unit.
Old Aug 6, 2006 | 07:05 PM
msinsky14's Avatar
Default Re: 4gen speaker help (TurboBA8)
well how do I check the rear speakers? they seem hard to get to, help please
Old Aug 6, 2006 | 08:07 PM
fast_honda's Avatar
Open the trunk, there are some nuts and bolts holding each speaker, just get them off and take the speakers out.
Old Aug 7, 2006 | 10:50 AM
msinsky14's Avatar
Default Re: 4gen speaker help (fast_honda)
ok thanks
Old Aug 7, 2006 | 06:55 PM
msinsky14's Avatar
nevermind, I took the head unit out and I think I have a bad harness b/c when I move it into different positions the rear will turn on, or maybe just the front right, etc. so what I did was I stuck some double sided tape under the head unit and it keeps the wires so that all the speakers are on, this is sooooo annoying
jdmem12000
Acura TSX
Feb 12, 2022 04:10 PM
GSblueRacing
Audio / Security / Video
May 23, 2004 12:31 PM
rota426
Jul 30, 2002 08:40 PM
