Only one side bass!
Old Jul 20, 2002 | 08:33 AM
rota426's Avatar
Default Only one side bass!
I'm not getting (signifigant) bass on the right-rear of my 94 LS integra. I have a Pioneer 4400 deck and polk gxr 6 1/2's in the back. Speakers up front work fine, and I've checked just about every aspect of the deck programing. Any suggestions?
TIA
Nate
Old Jul 20, 2002 | 11:36 AM
GSRaCeRbOI's Avatar
Default Re: Only one side bass! (styler7)
simple things to check but as a comp network engineer.. sometimes the simplest things are overlooked.. so w/ that said..
are you sure the speakers are hooked up correctly (polarity)?
are you sure your balance and fader are set to the middle positions not sure what other settings your HU has?
maybe the front speakers are just better (more efficient, better freq response, etc) than the rears?
try borrowing a friends speakers and hook it up to your rears to make sure the head units rear channels are working...
since you say right rear.. is the left rear OK? check to see that you didn't reverse the wiring/polarity (+ and -).. those are things I'd look into if I had this problem..
Old Jul 23, 2002 | 07:39 PM
philly-O's Avatar
Default Re: Only one side bass! (Teken)
you might also have the speakers out of fase, meaning that one is hooked up correctly and the other would be reverse. try switching +&- on the quiet speaker and see if that helps.
Old Jul 30, 2002 | 08:40 PM
rota426's Avatar
Default Re: Only one side bass! (peichie)
thanks for the help guys, but now i have hardly any bass in the front...****
Nate
Play_House
Sep 1, 2011 04:30 PM
hometheaterman
Audio / Security / Video
Jun 24, 2005 07:16 AM
FOUR-G
Jul 20, 2004 05:52 PM
